Guys I Really Need Some Cam Help
Old Oct 23, 2004 | 02:42 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
I posted this question but havent gotten any responses, i have a 388 cid with 8.5 compression, im gonna spray it, i want to put it under my 86 tpi with a cam i already have purchased for the prodject, 236/230 624/620 on a 114, what kind of computer issues am i gonna have? what kind of probs with running etc. , have th350 behing it with a 3500 stall , but dont want took much computer issues, is there a better cam that still has descent lift but smaller duration out there? or can i make this billet hydraulic roller i have work?
Old Oct 23, 2004 | 02:55 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
https://www.thirdgen.org/techbb2/sho...hreadid=264356
Take a read at that thread. That's an awful lot of lift for that given duration. Valve train wear will be at a high.
Old Oct 23, 2004 | 03:23 AM
ok, well i read that thread and it gave me some interesting points, i failed to mention i am running gm fastburns with 2.08/1.65's with springs good up to 650 lift, the heads i have flowed 310 int/ 218 exh @600 lift. from what i know they are pretty good even for fastburns, my main ? is what kind of computer and running issues am i gonna have?
Old Oct 23, 2004 | 07:18 AM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
a stock 1986 TPI ....with them cam specs . You do realize that intake setup runs out of air at 4800 rpm's right ? If your plan is that stock TPI .... computer problems arent what you should deal with first . It's going through a MAF correct ? A stock one flows around 450ish CFM . YOu need more than that I am guessing for that setup . What's the topend on that cam ( rpm's) I bet its way over 4800 rpms.
Call compcams .....tell them what you want to do ...they will give you a cam for what you want
Old Oct 23, 2004 | 11:20 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
It will run out of air sooner than that.
My 355 w/ TFS heads runs out of air at right at 4K. W/ the added air requirements of the 383, you may be lucky to get that far.
Old Oct 23, 2004 | 12:22 PM
so do yall guys suggest i change intakes? maybe the hsr or the tpis lt1 style or what do yall suggest? what intake gives the most air? is there a different maf system that can be used?
Old Oct 23, 2004 | 01:36 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
For the most part, any aftermarket intake will be sufficient. Maybe even the LT1 conversion. Of them, not sure which would be better. Probably a shorter runner design such as the Stealth Ram or Super Ram (I think, I may be getting them all confused).
A cam like that would definitly favor a short(er) runner, though.
Try a search, if you haven't already. Get a feel for what kind of combos people are running with what and the results they are getting.
Old Oct 23, 2004 | 01:47 PM
yeah that is kinda why i made this post, want any of yalls feedback from people who have been there done that and had issues, so pretty much i can get by with stock ecm but am gonna have to maybe size down cams and get a better intake later, i was already thinking this cam might be a little much , i was thinking of calling comp and trading it out with something smaller with lift around 510-540 and duration under 220 on both sides.
Old Oct 23, 2004 | 02:02 PM
yeah the tpis system is 895$, i think hsr manifold and fuel rails with regulator is like around 500$, i guess ill size down the cam, get it in the car under the tpi then see what happens and pick after that, i wonder how bad the tpi will run under nitrous?
Old Oct 23, 2004 | 02:09 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Out of curiousity, what's the bottom end look like? Specifically the pistons?
Old Oct 23, 2004 | 02:15 PM
coated weiscos, 30 cc dish for 8.5 to 1 compression, 6 inch manley racemasters, tfs steel crank, 4 bolt splayed and studded, it is a early 70's late 60's .010 block, made 650 hp on nitrous on the carbed setup but went with different pistons to do a efi turbo but got tired of all the crap to do the turbo so decided to put it under my tpi and spray it, but before i do i want to know what issues i will have, ill defineitely be prepared to upgrade the intake and probably will size down the cam
Old Oct 23, 2004 | 05:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
After you decided which you want to do ( upsize the intake ...or downsize the cam ) Call up a cam company . Like compcams , they will give you a pretty good recomendation for a cam .....even go custom grind . I have a custom grind picke dout from them ....and they still charged me an of the shelf price . As said before though ...do a search ( I hate hearing that too but .... ) check out the setup's people are running .... thne decide how radical you want to go
Old Oct 23, 2004 | 05:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
IMO, if you really want the most out of a setup, call Comp or someone and see what they can do as far as custom grinding goes. That gets you a cam taylored to YOUR setup.
Old Oct 23, 2004 | 06:13 PM
well the cam that i have is a comp cam that was a custom grind billet from them for the original turbo setup. i just want to get something that is more tpi ecm happy
Old Oct 25, 2004 | 05:21 PM
ok, well i called comp today and they gave me a couple of grind #'s to go with but they suggested i use a flat tappet cam so i dont have knock sensor issues. do you guys think that converting to a different intake would fix the lack of air problems or will i have to modify to a 730 ecm and ditch the maf? i would prefer to stick with the maf just for the simple fact of not having to convert if at all possible
Old Oct 25, 2004 | 05:45 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
I wonder why the suggested going to flat tappet to get rid of noise( knock sensor issues)???? What is the rest of your setup ?
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 14, 2015 08:25 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
