Modifying TPI fuel rail hard lines?
Old Oct 23, 2004 | 10:25 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
Has anyone cut the hard lines off and modified the fuel rail to tap fittings for braided lines? Aren't these lines press fit into the aluminum rail? Can they be removed easily?
Willie
Old Oct 23, 2004 | 10:33 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
I BELIEVE SUMMIT SELLS A PAIR OF FITTINGS TO ADAPT LINES TO THE FUEL SYSTEM...
Old Oct 23, 2004 | 10:51 AM
Willie's Avatar
My preference is not to buy adapters to fit into the existing hard fuel line ends (16 & 14mm) but to remove the hard lines and tap into the fuel rail. This would result in a much cleaner look.
Willie
Old Oct 23, 2004 | 11:26 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You could do like this..
Old Oct 23, 2004 | 11:32 AM
Willie's Avatar
That's it! Chris, what are the specs on the fittings, including the red plug in the front?
Willie
Old Oct 24, 2004 | 11:56 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I wish I remembered. somebody else did it and I asked them. I forget who.
I THINK.... 6an fitting and the front was just a Alum pipe plug.
Old Oct 24, 2004 | 08:49 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Willie
Hrmm.. You could drill 'em out and tap it to a 3/8 NPT..
-- Joe
Old Oct 24, 2004 | 09:21 PM
Willie's Avatar
The issue here is I don't know what to expect once I start drilling. Are the end caps simply plugs and if so, they look kind of large. Once drilled out, is there enough material left to tap threads? If not, what then? I just don't want to mess up a perfectly good fuel rail.
I'm going to contact Street & Performance. They work on these all the time from what I understand.
Willie
Old Oct 24, 2004 | 09:27 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Willie
Hrmm. I dunno. I ended up using holley rails on my conversion.
Good luck though!
-- Joe
Old Oct 25, 2004 | 07:03 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Willie can you Tig weld?
I know this is for LT1 fuel rails but Just apply the same to your stock rails with the fittings.
http://gmhightechperformance.com/tech/0409htp_snow/
Once I had the fuel line cut off, I squared the fuel rail up against the disc on my belt/disc sander and sanded on it until I had removed about .125 inches. Only remove as much material required to remove the rest of the steel line and get a flush surface for welding. Once you get the line out you can sand down the threads on the large diameter of the reducer fitting until it fits inside the fuel rail. While a lathe and a mill would have been nice for these operations, a belt sander will get the job done.
Old Oct 25, 2004 | 10:29 AM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
What you could do is take a fuel rail from a car that has the cold start injector and put your fitting there, then plug the original fitting. Just a thought!!!!!!!!!!!!!
Old Oct 25, 2004 | 11:09 AM
Guest
Guest
Posts: n/a
I have a couple rails laying around, I'll see what I can do with them if anything. I think that end piece is just a flat cap/plug with an o-ring or press fit thing of some sort. I'd imagine below that is just a hole of constant diameter, because from the way they'd have to machine it there wouldnt be any reason to do anything else.
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
