SDPC Vortec manifold swap
Old Oct 27, 2004 | 07:04 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Hey guys I did the manifold swap from for SDPC vortec heads. I am getting ready to install my primary coil and egr solenoid, But when i installed the SDPC manifold i also installed an EGR tube that comes with it and the tube is in the way of the coil bracket. Anyone here perform the same swap and have this problem? If so what did you do to correct it? Should i try and install the bracket on the d/s front or mount the coil to the firewall? Thanks,
Old Oct 27, 2004 | 08:53 PM
IrocJason's Avatar
Car: 1986 Iroc Camaro
Engine: 5.3 ltr
Axle/Gears: moser 9in, 4.56gear
Hi I did the sdpc intake swap but my car has HEI distributer with internal coil. The only thing I moved was the map sensor to the firewall. Try put it on the firewall it worked for me.
Old Oct 27, 2004 | 09:17 PM
vortec77's Avatar
Car: 86 T/A
Thanks for the response, Anybody out their have a seperate coil on their TPI that has done this swap?
Old Oct 28, 2004 | 07:58 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can mount the coil anywhere. Just fab up a new bracket for it to mount on the firewall, or some other convenient location.
Old Oct 28, 2004 | 02:34 PM
Shaun 90 Iroc's Avatar
Car: 1990 Iroc-Z
Engine: 350 L31 Vortec
i have a 90 Iroc tpi and i put the coil on the firewall.. the tube from the egr kit i did not use.. i just cut a piece of metal to cap that port from the intake base. I was told it was not needed for my application
Old Oct 29, 2004 | 05:34 PM
vortec77's Avatar
Car: 86 T/A
Did any of you guys also do a painless wiring install too? Im trying to finish my swap and get this thing running. I have 1 wire that goes to my VSS but the old vss had 2 wires. Im told i need 2 wires for the computer to see
the right amount of voltage. Im going with an 89' MAF TPI version. Anyone?
Old Nov 4, 2004 | 02:11 PM
89GTA_86's Avatar
Car: 89 GTA
Engine: 350 TPI W Vortec Heads
Transmission: 700 R4
How is you car running i am about to do the same thing?
Old Nov 5, 2004 | 07:48 PM
Kennerz's Avatar
Car: 88 5.7 Iroc, 2000 SS
Engine: Vortec Hot cam TPI/LS1
Transmission: Pro-Built/T-56
I have the coil mounted to the firewall with a long coil wire maybe 7" further away than before, works fine just make sure the mounting is solid. And I run the full EGR set up. makes it kinda a pain to install. I assembled my entire motor on a stand with headers installed (less distributor) and dropped it in the car.Putting that tube on the with the exhuast on in the car would suck, wasn't even that easy to do on a stand, everything bolted up ok, but there is alot of opportunity for leaks, just need to be very aware of what you are doing. My Egr valve had to be ground slightly to fit flat on the base. Need to make sure that SDPC Egr tube is welded at the correct angle. overall not hard. just as I said kinda a pain in the butt. For some reason this intake has alot of holes to fill, oh yeah and the fitting for the oil sending unit was a pain too. Car runs well though, ton's of torque, way more hp than stock, but still a TPI with no top end HP, but the great mid range almost make up for it.
Oh yeah, and the egr tube interfered with my AC housing at the fire wall , so the AC! mod was done.
$.02
Old Nov 5, 2004 | 08:24 PM
vortec77's Avatar
Car: 86 T/A
$.02
You used the old 1 terminal oil sending unit huh. I also had to get the Painless wiring kit (#60120) so i was able to use the three terminal oil sending unit/switch. The wiring kit came with an adapter so the old 1 terminal wire can be hooked up to the 3 terminal switch/sending unit along with the ground wire and the wire that goes to the fuel pump relay, so i didnt have to put up with that small fitting at the back of the manifold crap. So everything works off that one switch, Guage and all
Old Nov 10, 2004 | 07:24 AM
abcx09t's Avatar
Car: 1987 IROC-Z; 2012 Ford Raptor
Engine: Modified 350
Coil Location
I have the separate coil and the SDPC 350 V TPI. I put the coil on an "L" bracket I made and mounted to the firewall. I needed to remove the wiper blade screen to access the nuts on the far side of the wall. The coil is in almost the same place, just mounted to the firewall. Also, by the time I put all the other go fast goodies on, the EGR tube assy wasn't even needed. I went through all the trouble to have their tube welded to my header, then the chip programmer just bypassed that input anyway...so all for naught. I don't know why they push the EGR kit, don't need it.
Scott
Old Nov 10, 2004 | 08:49 PM
Scott57350's Avatar
Car: 1991 Z28
Engine: 355 TPI
I made a bracket off the runner bolt on the top pass side and mounted the coil there. there didn't want it there but theres so much crap over on that side to mount it anywhere else and I don;'t wanna drill into the firewall. I suppose i'll find a better spot over the winter for it
Old Nov 11, 2004 | 11:38 PM
Kennerz's Avatar
abcx09t,
I think the idea of the egr was to get it to pass the emitions testing. I know it can't pass the visual test. but I think it would help, thats why I have it plumbed in, if it even gets me .5 mi more to the gallon , or will pass ca emissions it's good to me. I know this alone doesn't make it exempt. Just hope I pass, at least all the emissions on my car is functioning. you don't have may choices in CA.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Fast355
Dec 2, 2016 06:33 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
jharrison5
Aug 19, 2015 05:53 PM
