Identify these 3 fittings on throttle body
Car: 2000 BMW M5
Hi guys, I finally got the 1969 fuelie headed 327 tpi conversion running tonight. Wow! Anyhow, what are the three hose connection ports for on the throttle body, pictured (2 large ports on the left, 1 small one on the bottom)? I have all 3 capped since I retrofitted a muscle car era, non-emissions engine with the TPI and didn't have anything to connect to them.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
If i remember it correct it should be.
Left side Topp: to CC
Left side bottom: to valve cover RH side
Under: EGR
Under: EGR
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
top right one goes to valve cover (breather, i guess, no pcv filter on it), lower one runs over to the fuel canister, and the little one on the bottom goes to the egr solenoid, i think.
KAM
KAM
Terrell351
06-13-2021 01:13 PM
Street Lethal
04-30-2019 12:14 PM
mdtoren
08-16-2015 05:45 PM
