Got the Port injected Small Block Chevy 454 Done!
Old Nov 3, 2004 | 06:47 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
Just put the finishing touches on the SB 454, running a Holley Stealth Ram intake and Sequential Port injection!
More pics at http://www.tpijeep.com/SPI454.htm
I am going to try and put it on the Dyno tomorrow or Friday and see what she will do, shooting for about 600 ft lbs of torque and 500 hp on pump gas.
Old Nov 3, 2004 | 07:16 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
WOW, motown block I guess ?
Looks sweet as hell
Great job man !
Old Nov 3, 2004 | 07:47 PM
TPIJeep's Avatar
Dart Iron Eagle, 9.375 deck, raised cam, spread rail.
Old Nov 3, 2004 | 07:57 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
Sure is a thing of Beauty!!:hail: :hail:
Old Nov 3, 2004 | 08:49 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You just did the same thing i want to do down the road!!! DANG its awesome looking and i am sooooo jealous right now!!! Read my post on 'where i see my car in 7+ years!" and i go thru everything i want to do. That motor is part of it!! LOL
Thats real nice power level your gonning for. What AFR heads are those? 210's 195's or 220's?
Old Nov 3, 2004 | 08:59 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I think you put the fuel rail on backwards, I think the fuel crossover is suppose to be in the front or upside down. Definitely a sweet setup though. Why are you going for a higher RPM intake for a off road car? Don't you want all the power down low like a TPI has?
Old Nov 3, 2004 | 10:16 PM
TPIJeep's Avatar
Thanks, The fuel and intake came with no instructions so I sorta guessed, would make sense to be down low to go around the Dizzy. The heads are AFR 210's fully CNC'd.
I went with the Steath because my current 415 falls on its face at 4000 with the stock TPI intake, figured I needed more flow and the Stealth was more cost effective over a Big Tube TPI.
Old Nov 3, 2004 | 10:20 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
I can see why you went with a HSR. Its not like you NEED the famous tuned port torque with 454 cubes under the hood!
Old Nov 3, 2004 | 10:55 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
the torque output of TPI with larger base/runners would be tremendous on that 454!!! But an HSR will make great torque as well cuz those 454 inches play a big part in taming the power band of that intake.
Old Nov 4, 2004 | 08:26 AM
speed88's Avatar
Car: 1988 Trans Am GTA
Engine: 383
That is my next project. When I get bored with my current 383 setup, a 454 sb it will be! VERY friggin sweet!! :hail: :hail:
Old Nov 4, 2004 | 09:16 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
This is indeed a trick setup.:hail:
Would you mind going through all the non-standard sbc parts you needed to get this together. Also, how much do you think this adds to the dimensions of the longblock as far as height and width are concerned?
Old Nov 4, 2004 | 05:36 PM
TPIJeep's Avatar
Well the bottom of the block is .800 wider, the heads are .325 taller and say maybe .600 wider at the top of the valve covers...
Non standard parts... Timing Chain, Oil pan, intake spacers (to make up for the wider spacing of the heads) You need a BBC oil pump shaft and a remote oil filter because the block doesn't have an oil filter provision. and longer pushrods..
The build was fairly simple as far as custom motors go.......
Old Nov 5, 2004 | 01:37 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Where did you get the intake spacers from or are they handmade?
Old Nov 5, 2004 | 08:39 AM
TPIJeep's Avatar
The intake spacers are a Dart product, I don't have the part number handy. The spacers for the front and rear of the intake had to be hand made. I just took a 1/2" thick block of hard plastic and "Hand" milled them to shape, and used roll pins to hold them in place.... ugly but effective! You can see them in one of the pictures..
Old Nov 5, 2004 | 12:16 PM
The Doc's Avatar
TPIJeep that looks like an incredible engine project! Is it going in your 1985 CJ-7?
Can I ask a few questions? Mind if I ask what camshaft you are using? Did you get your dyno results yet? Are you doing the tuning yourself? Are you using the GM ECU or did you get the Holley Commander setup?
Old Nov 5, 2004 | 05:54 PM
TPIJeep's Avatar
Its a Comp Soild Roller custome grind, short duration for torque .620/.630 lift. I am putting it on my dyno hopefully this weekend and am going to tune it out, I have the Accel Gen 7 ECM with a wideband 02 and Dual sync dizzy so tuning should be fairly easy.
Yes its going in my Jeep, wanted a hell of a lot of low end and the ability to use massive amounts of stupid pedal.
Old Nov 8, 2004 | 01:25 PM
Fevre's Avatar
Car: 89 Formula
Engine: 355
The cross over is meant to be in the front, the fuel feeds into the rear of the passenger side rail and exits at the regulator on the driver side rear. I used a straight AN fitting on the passenger rail then routed the fuel line back around the dist up against the firewall, on the drivers rail I used a 90 degree fitting. I tried a 90 on the passenger side but it was just too tight with the fuel line, dist/wires, dist hold down and vaccum fittings.
Nice job, eng looks awesome.
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
Kaweh
Aug 19, 2015 07:06 PM
