87 Tpi Ecm,harness-85 Tpi Won't Start?
Car: 85 IROC-Z
Engine: 5.0 TPI
OK, I put an 87 ECM and harness in my 85 TPI IROC, won't start.
Need some help w/wiring,
87 harness to ECM has 2 connectors that go to ECM, also seperate strand of wires w/ clear conn. that has 2 rows of 8 pins lettered a-h,i-p?
The 85 harness to ECM has 2 conn. to ECM, also 2 seperate strands, 1 w/same clear conn. as 87, and the other to a small gray conn. that plugged into the piggy back module on the 85 ECM.
I know the MAS from the 85 isn't needed for the 87, but what do I do w/ the plug just hanging there w/ 2 pink/blk IGN 12v wires and 1 brn/blk wire? Aren't the pink ones from the INJ fuses, and if so where does the 87 setup get its power for the inj.?
Also the clear plug w/2 rows of 8, most of the wires match in color, but a few are wrong, like the two black wires that are coming from the injectors on the 87 setup. They are now connected to a red/blk and pink/blk. This can't be right!
I was told that I could put the 87 setup in place of the 85 w/o these problems, I knew better, nothing is ever easy if someone tells you, oh yeah, it will hook right up!
Anyway if someone else has successfully done this before, PLEASE let me know if there are certain wires I need to move around on the clear plug to the harness under the pass. side dash?
Another thing is the fuel pump only runs if I hot wire it, worked fine with the 85 system! Term. G on the ALDL conn. won't even power it up.
Moderator/TGO Supporter
Car: 1997 Z28
I had the same trouble when i did my engine swap earlier this year. I had to buy an aftermarket harness, well i didn't have to, but i plugged it in, and it fired right up
PM a guy named trickster, he will have the wiring diagrams you need.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Are you sure the 87 harness wasn't messed with? I upgraded my 85 with an 87 harness and a 165 ECM. I ran into no problems. Had I kept my original distributer, the distributer plugs would have had to been modified, but that would have been it. This is really a plug and play type of deal.
Car: 85 IROC-Z
Engine: 5.0 TPI
Thanks and any other help would be greatly appreciated, I'm starting to go
Doug
I don't remember having a clear plug. What did it plug into?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The clear plug would be the Instrument Panel connector on the right side of the dash.
It has power to the ECM, Injectors, ESC connections, brake switch for TCC, and others. You will need a schematic of the exact car to find what each does, but there are some important ones there.
Car: 85 IROC-Z
Engine: 5.0 TPI
Or anyone?
a little more info
This thread may help.
https://www.thirdgen.org/techbb2/sho...%2FP+connector
There are a few others that have pinouts forthe I/P connector but I didn't see them in my 2 sec search.
Check the search with different terminology, it's there (I've seen it)
Good luck.
Good luck.
Originally posted by JOHNCOO5
Yeah thats the one, hey Jim do you have any info that might help me?
Or anyone?
Or anyone?
Car: 85 IROC-Z
Engine: 5.0 TPI
I/P connector from under pass. side dash in my 85
I don't know what to tell you. All of my under-dash wiring plugged right into the 165 ECM with absolutely no modifications necessary. Either your wiring is hacked, or your computer is FUBARd.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Did you replace all of the 85 wiring harness with the 87 harness or are you still running some of the 85 harness inside the car under the dash and the connector at the driver side firewall bulkhead?
Car: 85 IROC-Z
Engine: 5.0 TPI
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Well, as I'm sure you're finding out the hard way, there is quite a bit of difference in the wiring between those two years as far as the under dash wiring goes. You will find that not all the pin connectors and wires are compatible with each other. give me a moment to scan the two firewall connectors in and you will see the difference. That other connector that you were asking about is connector C207 and I don't believe that it was in the 85 models by that name, will have to check the schematic.
Car: 85 IROC-Z
Engine: 5.0 TPI
I sure wish mine could be as simple as Jim85IROC's swap was.
Car: 85 IROC-Z
Engine: 5.0 TPI
Hey John, before I can get the ECM wiring for you on the 85 I need to know what engine was in it originally.
There was an exhaust leak which ignited a sudden fuel leak and burnt the wiring harness. I was unable to find an 85 harness at the time and didn't want to have a bunch of repaired wiring. wondering if I should have just repaired instead:lala:
I'm not sure but I think that Jim did a complete wire swap out when he did his.
Car: 91 camaro rs
Engine: 350tpi
I have almost the same problem. I've got an 89 and I swapped the v6 to a 350. I got all the wire harnesses from an 86 firebird. The fuel pump doesn't do anything on mine either. I know the wire harnesses are different. I haven't even tried to spray starting fluid in it to see if it will start. I just put the motor together last week. I would appreciate it very much if you guys would let me know how this turns out.
Re: 87 Tpi Ecm,harness-85 Tpi Won't Start?
johncoo5 can you please help me. I'm having the same problem you did with 85 to 87 harness conversion. Can you please tell me what you did and what you had to repin. I'm using a 87 engine harness,with the 85 c100 harness.Please help so I can get this car to run once again. Thanks.
Sanjay
Aug 12, 2015 03:41 PM
