How does this setup look?
Old Nov 20, 2004 | 11:46 PM
Hg's Avatar
Hg
Car: '87 Z
Engine: 355 in the works
This is what I'm looking at, and I have the shortblock as of right now, but I'm still throwing around ideas for the topend.
350 4 bolt main, .030 over
Forged TRW .100 dome pistons
Forged Polished eagle I beam rods
Forged eagle crank
ARP fasteners
Miniram III w/ Edelbrock ETEC 200cc heads(or Miniram with AFR 195s?)
30# SVO injectors
CC306 or GM 847 cam ????
Comp retro roller lifters, Comp pro magnum 1.6 RRs, Comp hi-tech 1 piece chromemoly pushrods
I have a 700R4, and it will have a 3000rpm stall. How streetable or unstreetable would this setup be, and how long do you think it would live? Is it grose over-camage? I'm aiming for 400rwhp. Any comments or suggestions are appreciated.
Old Nov 21, 2004 | 12:19 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Not sure what the cam specs are for either of those are, however, I do know that power is more easily made when better heads are used.
My vote goes to AFR/Miniram combo.
Old Nov 21, 2004 | 12:31 AM
Hg's Avatar
Hg
Car: '87 Z
GM847: 232/242 - .539/.558 - 112 LSA
CC306: 230/244 - .510/.540 - 112 LSA
Old Nov 21, 2004 | 08:03 AM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The miniram won't bolt up to the E-Tec heads though... It will work on the GM Fastburn heads, but not standard Vortec heads (or E-Tec).
Old Nov 21, 2004 | 08:44 AM
305RSlc's Avatar
Car: 1991 Z28 Camaro
Transmission: 700R4 that will magically turn into a 6 speed one day.
What's the difference between Fastburn heads and regular vortecs other than the metal they are cast with, valve size, and runner volume? And, isn't the E-Tec just Edelbrock's version of an aluminum vortec head?
Old Nov 21, 2004 | 12:03 PM
TPIJeep's Avatar
Engine: 7.4 L of Small Block Fun...
Whats the dome cc volume? I think your getting into a high compression situation. The afr 210's with the 76 cc chamber may be a good way to go but we need to figure you actual compression ratio first.
Old Nov 21, 2004 | 12:12 PM
TPIJeep's Avatar
Just did some calculations,
If the dome volume is say only 6cc
Head gasket thickness or .040"
Head gasket bore of 4.080"
Piston down bore at TDC of .005"
If your head chamber is 76cc your looking at 10.14
If your head chamber is 70cc your looking at 10.88
If your head chamber is 67cc your looking at 11.30
Don't try and leave the piston down bore at TDC any more then .005" because you will have an incurable ping on 93 octane due to the large quench gap.
Now if you go with a 2 valve relief piston with say 3cc of valve relief
76cc gets you 9.21
70cc gets you 9.80
67cc gets you 10.14
Hope this helps... btw I just got my AFR 210's and they are extremely nice!
Old Nov 21, 2004 | 05:00 PM
thirdgen88's Avatar
Car: 1995 Corvette
Well, the fastburn heads are also drilled for the standard patten.. The vortec heads (or e-tec) are not.. I emailed TPIS and they said, well, here's the quote:
"The Mini Ram III will not bolt up to a vortec head without drilling the head and tapping it for new bolt holes. " -TPIS
Old Nov 21, 2004 | 05:22 PM
1320 Right Ln.'s Avatar
For a 355 motor, you really would be better off with less than 195-200 cc intake ports on the heads. you'll probably see more overall torque power with something like 170-180 cc's. combine that with a tpis miniram... and that'll be some awesome velocity, and more than enough flow. Just a better combination of parts IMHO. Oh, n' that GM 846 cam looks nice, I was really thinking about getting it.
Old Nov 22, 2004 | 09:49 AM
305RSlc's Avatar
He makes a good point. In Super Chevy, their dyno mutt "Spot" was tested with E-Tec 200 and E-Tec 170's. With the 200's it was run with a Victor Jr. intake. With the 170's it was run with an air gap...I know where comparing apples to oranges here since this is carb but still. The end result was that the 170's actually made more overall power, more peak power, and more power under the curve than the E-Tec 200's.
Old Nov 22, 2004 | 11:28 AM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I like the MiniRam but would go with AFR 180 heads and Competition port if $ allows. I would also stay away from the 306 cam because of the extra long exhaust duration. Go with a Comp custom ground Hyd. Roller 230/230 @.050 112 lsa installed between 109-110.
The AFR heads work well with a single patter grind.
Try to go with a flattop piston and get the chamber down to 60-62cc. Zero deck the block and use a .040 head gasket. You will get the benefit of high compression and ability to run pump fuel.
www.geocities.com/dzperf
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
