distributor gear
Old Dec 7, 2004 | 09:17 PM
DRENNON's Avatar
distributor gear
Just did something stupid.Pulled the distributor gear to adjust end play without marking it.The gear will go on either way.The wrong way will be one half tooth off.How can I find which is correct?
Old Dec 7, 2004 | 10:07 PM
Guest
Guest
Posts: n/a
Its all relative. Just stick it all back together, set the timing, and be done with it.
Old Dec 7, 2004 | 10:50 PM
meangene83's Avatar
Car: 91 formula
Engine: 355
the side with the indent points the same way as the rotor.
Old Dec 8, 2004 | 08:57 PM
DRENNON's Avatar
distributor gear
Distributor is installed and working fine .
eightsixseven
Dec 16, 2024 01:50 PM
jklein337
Sep 19, 2018 06:23 PM
beastin91rs
Oct 9, 2015 07:38 AM
mddaniel
Sep 8, 2015 05:16 PM
86IROC112
Aug 17, 2015 07:57 PM
