need help fast please!
Old Dec 6, 2004 | 05:45 PM
1987gt's Avatar
Car: 1989 GTA
Engine: 350 TPI (Many Mods)
i have a 1989 gta 350TPI it started running bad so i checked the fuel presure and it was 62 lbs way to high so i changed the regulator it was a bbk adjustable that did not work so i ordered a universal aeromotiv regulator hooked it p front whare the rubber lines are and it still reads 62 lbs itstill will not adjust up or down i dont know what to do please help what should i do next? o and the fuel pump is a TPIS 400hp pump it has been in the car for a year or so.
Old Dec 7, 2004 | 11:39 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Will it not release pressure at all? Have you checked the fuel filter? Are all of th injectors firing? Try an Ohm test.
Old Dec 7, 2004 | 12:43 PM
1987gt's Avatar
Car: 1989 GTA
i called TPIS today and they told me to change the metering block under the afpr that i is probablysticking i never thought of that i tought that the regulator was the diaphram and the bbk housing but he said that the regulator is in the metering block so im going to return the aeromotive afpr and get a reglator from GM.
Old Dec 7, 2004 | 12:45 PM
1987gt's Avatar
Car: 1989 GTA
if it was the filter it would not get enough presure not to much.i did not check the injectors though how do i do that? just in case this metering block doest fix it.
Old Dec 7, 2004 | 03:38 PM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
Also make sure your return line from the fuel rail to the tank is not restricted
Old Dec 8, 2004 | 09:58 PM
1987gt's Avatar
Car: 1989 GTA
how and why would that happen all of a sudden? and how do i check that? also do you know if thats true about the bottom square base that holds the regulator he ses that it is the regulator and it has a valve in the base is this true? he also ses that gm sells the whole bottom base and regulator together he ses you cant get them seperate if this is true then why does jegs and summit all sell these so called regulators with just the diaphram,spring and housing?
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
