sanding tpi
Old Dec 20, 2004 | 07:32 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
sanding tpi
hey if i sand down my tpi is it easy to get the polish effect to it. What will i need to do? thanks,bryan
Old Dec 20, 2004 | 09:37 PM
Ozzy88GTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
I don't know about easy but it is time consumming. You start with like a 60 grit and work your way to a 1500 grit. If you put some time it will take you one day for the plenum and one day each for the runners.
To get the mirror finish it takes a lot of patience.
Her are two shots of mine when I did them:
http://home.earthlink.net/~tokrah/sp...m-polished.jpg
http://home.earthlink.net/~tokrah/spring04/runners.jpg
And the engine as finished:
http://home.earthlink.net/~tokrah/spring04/complete.htm
It is worth spending the extra time doing it if you want the engine to shine.
Here is the Tech Article showing one of many ways of doing it: https://www.thirdgen.org/newdesign/t...umpolish.shtml
-Ozzy
Old Dec 21, 2004 | 12:16 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
thanks for the help it sounds not to bad.
Old Jan 4, 2005 | 05:05 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
Ozzy. How did you get in between your runners. When i did alittle port work on my plenum i polished it alittle also. But i still dont know how you poluished in between
the runners.
Old Jan 4, 2005 | 05:36 PM
Ozzy88GTA's Avatar
Engine: 5.0 TPI
The runners are a big PITA if you ask me. It took me as long to do one side of the runners as it did for the whole plenum.
The surface of the runners is not as rough as the plenum so you can start say with like a 400 grit or even 600 grit. To sand in between the tubes I cut the sand paper in like 1" strips long wise on the sheet. Then put duct tape on the back side of the sandpaper strip to reinforce it, otherwise they will tear very easily. Then secure the runner to a vise or between the legs and use both hands on the ends of the strips to go back and forth like if you were polishing shoes. To polish with aluminum polish use 1" strips of terry cloth and buff the same way as with the sandpaper.
I also used my Mouse sander and the Dremel with polishing wheels for everything I could reach.
Hope that helps,
-Ozzy
Old Jan 4, 2005 | 08:43 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
thats what i had in mind. I should have known it wasnt gonna be half A** easy. Thanks for the info though man.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
firebirdta84
Interior Parts Wanted
Aug 30, 2015 09:28 PM
Sanjay
Aug 12, 2015 03:41 PM
