swapping 305 TPI over to a 350. what do i need?
Old Jan 2, 2005 | 10:01 PM
GTAman's Avatar
Car: 1988 Trans am GTA
Engine: corvette 350 swap
Transmission: t-5 swap
Axle/Gears: 3.27:1 borg warner 9-bolt w/ PBRs
hey guys,
i'm planning on swapping my TPI set up from my LB9 305 to a 350. what components do i need to make it happen?
-Mark
Old Jan 2, 2005 | 10:08 PM
Silver_IROC_87's Avatar
i beleive all that is needed are the ECM and block.....dont quote me though
Old Jan 2, 2005 | 10:18 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Also the knock sensor for a 350... the 305 sensor won't work.
Old Jan 2, 2005 | 11:08 PM
GTAman's Avatar
what about in the department of fuel injectors, compression, heads and type of computer?
-Mark
Old Jan 3, 2005 | 12:44 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You will need the larger injectors off of a 350 motor. The PROM only needs changed. The whole cooling system is fine. Knock Sensor if going to a different year. The heads from a 305 can be used on a 350.
Old Jan 3, 2005 | 01:42 AM
GTAman's Avatar
do you know how big the injectors are on the 305 compared to the 350?
also, would there be any problems with compression?
also, someone said i needed the timing unit off the old engine. is it true?
-Mark
Old Jan 3, 2005 | 10:16 AM
Tibo's Avatar
Car: 1991 Z28 Vert
The 305 injectors are 19lb hr and the 350 are 22 lb hr. Compression will be fine as long as you get the correct size pistons. What are you refferring to as the "timing unit?"
Old Jan 3, 2005 | 08:49 PM
GTAman's Avatar
in another post on here someone said i needed the timing unit and described it as a black box (lol great). that's all i know.
as for compression, this block i'm buying has pistons, crank, oil pump and pan and just needs heads manifold and my fuel injection. i have no clue what kind of pistons are in there. what will happen if i build the motor and the compression is off?
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
