Throttle body thing
Old Jan 18, 2005 | 08:54 PM
Tribe's Avatar
Car: 1992 Z28
Throttle body thing
Can someone tell me what this is? It is a hard plastic tube that connects to the underside of the throttle body. I read the haynes manual when I removed my throttle body and it did not mention this.
Tribe's Avatar
Car: 1992 Z28
here is a pic from the underside of the throttle body.
Old Jan 18, 2005 | 09:11 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
if i am not mistaken it connects to your emmissions carbon cannister or ac vacuum, i could be wrong though, follow the line and see where it leads
Old Jan 18, 2005 | 10:01 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
The one that connects to the underside of the throttle body is for the EGR...
Old Jan 18, 2005 | 10:52 PM
88cam's Avatar
I have to replace all my vacuum lines for the same reason, dry rot and such, everything broke. So I found some drawings of how they were layed out and I also found a post in this forum of what I could use to replace them.
http://chevythunder.com/fuel%20injec...um%20lines.htm
for the layout and
http://store.summitracing.com/defaul...6&N=110&view=2
for the new lines
I hope this helps
Old Jan 19, 2005 | 08:19 PM
Tribe's Avatar
Car: 1992 Z28
Thanks everyone for the replys.
88cam your links were very helpful.
I just got a piece of tubing from the auto store and connected the 2 lines together for now.
Old Jan 19, 2005 | 08:40 PM
89Formula5.7's Avatar
Car: 89 Formula 350
Engine: L98 w/ Stealthram
Axle/Gears: 9 bolt 3.27
Yeah, EGR tube that mounts by the remote coil.
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
justin57
Aug 20, 2015 07:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
