Distributor question
Old Jan 23, 2005 | 10:40 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Search is down, so I couldn't hunt for this question.
Are the 85 and 86 dist. different from the 87 and up? Or is it just size and the actual way they function the same?
Old Jan 23, 2005 | 03:23 PM
Vader's Avatar
Yes, the early TPIs had a different distributor, with an integraterd ignition coil. Later types had a divorced (separated) ignition coil and smaller cap.
To confuse matters even further, the early TPI engines used a different distributor cap and rotor than other HEI ignitions from GM. The TPI cap is lower and slightly wider:
Old Jan 23, 2005 | 06:30 PM
Joe_L's Avatar
Car: 1995 Z28
So... can I still install a small Dist on the old system, or will it be a problem?
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
