Friend Wants Ro Polish His Tpi Shiny
Old Feb 7, 2005 | 03:23 AM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
Hey my friend has noticed a few people have polished tpi's . he wants me to help him get r done, but i have no clue as how to do it correctly, can anyone on here point me to the right material to do and maybe some pointers so i dont botch anything up on his stuff
Old Feb 7, 2005 | 05:40 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
here is mine:
I basically used these directions generally:
here
Old Feb 8, 2005 | 07:47 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
That looks great novass. not to over done. Perfect in my book!!.
like he said the gm tips page is great info. You cant go wrong.
Old Feb 8, 2005 | 09:33 AM
Ruiny's Avatar
Car: 86 trans am
Transmission: T 56
that looks amazing
Will the finish stay like that? Or will it need some sort of maitence to keep it looking that great?
Old Feb 8, 2005 | 01:22 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
Originally posted by Ruiny
that looks amazing
Under the hood everything collects a lot of dust, and any water at all will cause a lot of water spots. For it to look good once its done you'll have to polish it from time to time depending on how often you drive the car, but the other side of it is that you can just let it lay however long and with some mothers or blue magic get it back to perfect again.
Oh, and its addictive, I just got done with my alternator, my 52mm throttle body, and my track rims. Next up is the accessory brackets and the AC lines and evaporator.
novass, i'm drooling over your car, but I see something missing, looks like a hell of a coolant leak you're going to have. Have you figured something out for the upper radiator support that looks better?
Old Feb 8, 2005 | 02:50 PM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I have one of those new air cooled engines! I have been waiting for my AC Delete pulley so I have not finished the full install yet, plus there is salt on the roads up here.
Ruiny,
I Zoop Sealed all the aluminum on my engine so that I should not have to polish it with blue magic etc. I used alum. polish in the past and it worked out ok, however, I figured I would try the zoop seal. Many that have used it says it works geat. All I need to do to clean it is use some mild cleaner to remove the oil and a soft cloth. We will see how long it lasts under the hood...
Old Feb 8, 2005 | 09:56 PM
smitty62's Avatar
NOVASS--where did you get that piece of aluminum intake tubing with the 90 degree bend? I've been looking for one! Thanks!
Old Feb 8, 2005 | 10:18 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
That elbow came with his Procharger kit I am sure.....
Old Feb 9, 2005 | 05:52 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
yup
Old Feb 9, 2005 | 05:58 AM
BADASS91B4C's Avatar
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
u can get the polished aluminum intake tube from summit racing too
vor-4gh112-058 ........... $94.95 or
tfs-3150800 ................. $89.95
Old Feb 9, 2005 | 07:05 AM
MIDNITERIDER's Avatar
Car: 1988 Formula 350
Transmission: 700R
Axle/Gears: 9 Bolt...3:27
Question...that polished tube from Summit; seems to fit a TPI intake even though it is for a LT.....will this fit my TPI and will the MAF sensor be in the same original place. Pics would be helpful. This looks like a great appearance mod!!!!
Old Feb 9, 2005 | 03:53 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I'm using the LT1 elbow on by 1989 Trans Am TPI with MAF. I had to buy another 4" hose to move the LT1 elbow away from the throttle body to line up with the MAF. I then had to move the MAF towards the passenger side around 4 inches. Made up a special bracket of 1" X 1/8" aluminum to move the MAF.
The round side of the LT1 elbow is 3 1/2 inch in diameter. You will have to make an adaptor to fit the 3" diameter of the MAF. I emailed Trick Flow and told them there was a demand for this item in conjunction with a TPI car. Hopefully they would come up with a kit.
I know of two cars here locally including mine running with the LT1 elbow. Dyno Don is also considering it. He picked up 16HP with his custom cold air kit on his Trans Am from stock. Allen
86IROC112
Sep 29, 2015 04:07 PM
Keith5
Aug 27, 2015 04:37 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
