TPI Airfoils?
Old Feb 19, 2005 | 08:26 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
TPI Airfoils?
Anyone try these things?
Worth it.?
Old Feb 19, 2005 | 08:29 PM
91 z28 350's Avatar
Car: 91 Z28
I got 1 off ebay for $20 didn't do anything
Old Feb 19, 2005 | 08:53 PM
kairles's Avatar
Car: 89 IrocZ/17 LS 1LE
Engine: 383/LGX
Transmission: 400/TR-3160
Axle/Gears: 3.08/3.27
I bought a TPIS air foil cost me $50 and did nothing, don't waste you money on an air foil
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
i had one on my original throttlebody, a hypertec airfoil. they're suposed to add 10 hp or so. some are better then others. mine surely didn't hurt anything. BTW its for sale.....
Old Feb 19, 2005 | 09:11 PM
smithtc's Avatar
On stock engines they have been shown to add from 0-4 horsepower...sometimes a little more. This is after adjusting the Air/Fuel ratio to compensate for the airfoil (which works for its intended purpose) on a dynanometer with before and after testing. You won't "feel" that, and will be hard to tune the extra hp potential in the real world without a dyno and a/f meter handy.
The more power your engine makes, using more air, the more effective this piece becomes...since it does help limit the "Head" loss through the throttle body opening...however small that help might be.
Once one is making High HP though, might be better to install in something like a monoblade.
It's a small piece of the puzzle, not one of the major players for enhancing efficiency...but it can help...especially if your looking for every little bit (which puts you 1st at the finish line).
My $0.02...
Old Feb 20, 2005 | 02:50 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Why would you need to adjust the AF Ratio??
Computors do that for us....
Old Feb 20, 2005 | 06:34 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Chip burning
Old Feb 20, 2005 | 06:41 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
I didnt even mean chips...Why would you need to tune the car for the extra 30 CFM the airfoil flows...EFI Systems do it for us!
Old Feb 20, 2005 | 07:01 PM
406TPI's Avatar
Car: 1985 IROC-Z
I'm not saying you would, I was merely saying, that's how you adjust A/F ratio. You are right, the ECU will do it for you as long as you are running in closed loop, however, dyno runs are done at WOT and thus the ECU is in open loop. The only way to properly change A/F ratio in open loop is with a chip burn.
Old Feb 21, 2005 | 10:31 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
I suppose you could say they help, but it is a little hard to "feel" an extra 5 horsepower........
Old Feb 21, 2005 | 11:11 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Saw someone post dyno results before and after installation of a air foil on a vette...........+1 HP
Old Feb 21, 2005 | 11:17 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
Yeah, but it looks real nifty,
and all the chicks dig it!
Priceless
Old Feb 21, 2005 | 11:28 PM
anondude13's Avatar
Are you sure about that?
Old Feb 21, 2005 | 11:33 PM
Chrome's Avatar
Car: 92' RS Camaro
I don't think its technically open loop, but I know that when Power Enrichment is on it locks the BLM basically rendering the Oxygen Sensor useless basically making it "open loop".
Old Feb 22, 2005 | 08:02 AM
406TPI's Avatar
Car: 1985 IROC-Z
Yeah, I'm sure about that.
Old Feb 22, 2005 | 06:08 PM
BC GTA's Avatar
Car: 1989 GTA
Engine: 5.0 TPI
Transmission: T-5 WC
Axle/Gears: Yukon 3.73
I could not find the magazine article; however, Holley claims in the September 2002 issue of GM High-Tech Preformance magazine their air foil produced 5.8 hp increase. See it here:
http://www.holley.com/HiOctn/ProdLin...B/120-140.html
Old Feb 22, 2005 | 06:19 PM
nick418's Avatar
Engine: L98, Hemi 6.2
i have one. Seems like it didnt do anything. Paid 50 bucks
Old Feb 22, 2005 | 06:29 PM
Car: 92'Camaro RS
Engine: a loud one
Funny no dyno charts to back that claim up.
Old Feb 22, 2005 | 10:36 PM
GTA matt's Avatar
Engine: L98/383
Axle/Gears: 9"
Oh, the best thing about the air foil is that mine made a real high pitched wistle at idle. some dude thought i had a turbo.... didn't tell him otherwise
stalkier
Dec 6, 2015 11:25 PM
kairles
Oct 26, 2015 09:13 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
