305 TPI in the IROC vs. 305 TPI in T/A
Old Feb 22, 2005 | 12:34 PM
Fakebacon's Avatar
Car: 70 Pontiac GTO clone, 96 Impala SS
Engine: 350 rocket(A), LT1(B)
Transmission: If it shifts hard, its like mine.
Axle/Gears: Love me some 373's
I was wondering.. 305 TPI in the 88 IROC vs. 305 TPI in a 89 T/A...
What makes the difference?!?!!?! My mom has an 88 IROC with the 305 and it hauls @ss! My girl has a 89 305 in her T/A and it just doesnt compare... is it as simple as the rear gears or does the IROC have a differen set of heads/cam?!?!
Old Feb 22, 2005 | 01:10 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
There will be a difference in how well tuned a car is of course, that aside it could be the gears. The other difference is on the 89 model years they did away with the cold start injector, but that would not make a difference. It could be mileage, lots of stuff.
Old Feb 22, 2005 | 01:57 PM
Goumba T's Avatar
Car: 1990 TA
Engine: LB9 305
Transmission: 4L60
Also they both have different intake designs. The camaros have a more straight path. Tech data page says this is worth ~10hp(?). Doubt you'd notice that as well as you say though.
In addition to what Tibo said, weight also. Does the TA have all power options? How about the IROC?
Also you didn't mention what transmission each had.
Old Feb 22, 2005 | 02:23 PM
razor's Avatar
Car: 1992 GTA
Axle/Gears: 4.10
Are they both automatics or is one a 5 speed. Different tranny=different cam in the 305's.
Old Feb 22, 2005 | 02:36 PM
Fakebacon's Avatar
I think they both share the 700R4. They also both have all the power options but cruz.
Old Feb 22, 2005 | 04:12 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
could be a few things.....
maybe the TA is a bit heavier???
maybe gearing in the Iroc is a bit higher
maybe tune up?
also it is said to subtract about 5 hp from the TA/firebirds cuz of the air intake design. that could affect some performance
Old Feb 22, 2005 | 07:07 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
same cam in 88-89 for 305 and 350 so no difference there, thats assuming no cam or engine replacment with non stock. Gears, posi, transmission, tires and how worn out / in tune will make up the rest of the difference. It is the same motor either way stock.
Old Feb 25, 2005 | 03:25 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
did everyone forget that TBI was the base engine for the IROC and i believe the TA as well? maybe the TA has an L03. otherwise it shouldnt be that much different. that iroc should have the peanut cam so i am sure it isnt that much of a stormer to begin with, and if the TA is that much slower it could be TBI.
83ho86tpi, i'm pretty sure the 305 and 350 didnt share the same cam untill the speed density years, 1990 and later.
Old Feb 25, 2005 | 03:59 PM
Fakebacon's Avatar
How about building codes in the glove box. You guys know any of the codes for the different rear ratio? Or the motor? TPI code vs. TBI code? I know the codes for my B body but are they the same GM codes on the F bodys?
Thanks again for all your help.
Old Feb 25, 2005 | 05:33 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
yup, same cam profile for 350 and 305 tpi for both years 88-89. That is what it says in my 1982-1992 camaro performance / history book. I would scan the page with all the cam details for the different years.....If I still had a scanner. My ex got that in the break up.
Old Feb 25, 2005 | 09:21 PM
Vader's Avatar
Look at the PROM in both.
Old Feb 25, 2005 | 09:28 PM
NEEDforSPEED's Avatar
wight is also a facter, the T/As where heaver
Old Feb 25, 2005 | 09:39 PM
ZZsmpch's Avatar
You could have two identical IROCs and see a difference in performance. Besides the obvious gearing and weight, just the state of tune, age of plug wires, type of gas that was run through them througout their lifetime, etc. can have an effect on performance. What's the mileage of the cars, how were they broken in when new? There could be a lot of variables involved.
Old Feb 26, 2005 | 06:11 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
gears will be the most noticable. The T/A may have 2.73 gears which makes the car seem kinda dog slow.
The Iroc may have 3.23 or 3.42 gears, or even possibly 3.73 gears.
I know when my 88 formula went from 3.23 gears to 3.73 gears, it would haul *** from any speed.
Old Feb 27, 2005 | 10:04 PM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
actually the iroc only came with the tpi.... the TBI was the base for the r/s.... as far as the trans am as i am not sure what the "base" option was but i bet it was also the tpi and the firebird had a tbi
Old Feb 28, 2005 | 11:29 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
83ho86tpi, i will not dispute that, you have the book and i was going from memory LOL.
86IROCTHD, you are incorrect. the TBI engine was the base engine in the IROC and the Formula Firebird, so i assume it was the base engine in the Trans Am as well. the TBI 305 was the optional engine in the RS. I am not saying that the Trans Am in question here has TBI, but it would be a possibility.
Old Feb 28, 2005 | 04:44 PM
83ho86tpi's Avatar
Car: trans-am
Engine: tpi
I saw a iroc with tbi and swore it was a fake. I almost tore it apart trying to prove it was just a set of stickers and wheels. Everything else checked out on it but I still was not sure. The book I have just gives performance and upgrade info, so I am not sure if there is a tbi iroc. im sure the answer is on the history / restoration post though.
Silly question for you Fakebacon.... have you looked under the hood? Are they both tpi? Has one been replaced with a 350 from a previous owner?
Old Mar 1, 2005 | 11:14 PM
BCdawg57's Avatar
Car: '91 Z28, '13 Civic EX-L
Engine: 355 LT1, 1.8 I4
Transmission: T56, 5spd auto
Axle/Gears: 10 bolt 3.42(as long as no breaky)
The IROC's did come with the L03 as a base engine in some years. The TPI was an option.
Old Mar 2, 2005 | 08:27 AM
Fakebacon's Avatar
83ho~
Both motors have the TPI badge on the TB so I guessed they are the same in that aspect. The 89 T/A was just aquired this past summer and I don't know much about its history. The IROC on the other hand my mother has been the one and only owner. I fogot to mention, the Iroc is also a convertable, but I have always heard convertables are built a lil more sturdy so they won't flex as much and thus, making em more heavy.
Old Mar 2, 2005 | 04:21 PM
mettalicirocz's Avatar
Car: 1986 camaro, 1993 nissan altima(winter beater, 1992 mustang (summer daily driver)
Engine: 350tpi
Transmission: 700r4 with shift kit
If the 89 T/A is getting spanked by a drop top 305 IROC, then it is really out of tune or is just plain wore out.
Old Mar 3, 2005 | 01:27 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
That's weird. Convertables flex more and weigh more. Something's not right here. Do either have G92?
BTW, there were TBI IROC-Z's, but they were few. If we could only see pictures of both of these cars I'm betting it would be alot easier to solve.
Old Mar 3, 2005 | 05:40 AM
swisscheese's Avatar
Car: '91 Z28
Engine: LB9
The official imported IROCs in Switzerland have TBI, auto and 15"-wheels. But thats GM Europe...
Happy, mine was imported by a private person who knew what to order!!!
Old Mar 3, 2005 | 07:37 AM
Fakebacon's Avatar
G92?!?! What code is that for? Sorry if I sound dumb but I'm a lil new at the F~bodys.
As for pics... Ill take one right this sec of the T/A's motor. They will be the first few pics here...
www.mobog.com/fakebacon
Stay tuned for the IROC.
PS. Where the heck are the build codes on the T/A?!? They aren't in the glove box like in the IROC... Or under the hatchback like I thought they were.
Old Mar 3, 2005 | 07:58 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
On the firebirds, the label is usually in the center console, glued to one side, or, in the locking compartment in the hatch, on the back of the door...... Mine fell off, so it resides in the Helms service manual...
Old Mar 4, 2005 | 12:38 AM
Car: '91 Z28
Engine: LB9
G80, G92
one is for locking axle and one is for 3.23 gears.
Old Mar 4, 2005 | 04:57 AM
Fakebacon's Avatar
Yeah, the IROC is... Does one nice burn out if I say so myself. The T/A is a peg leg.
Akinnepa
Convertibles
Aug 26, 2015 10:54 AM
wruiz
Aug 13, 2015 09:07 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
