Tpi Boggs
Old Mar 3, 2005 | 11:14 AM
TenochZ's Avatar
Car: 88 Iroc
Engine: 305 tpi
Transmission: auto 700r4
Tpi Boggs
Great site guys, new guy here.
Ive been reading for a while. I used to post in another iroc site that doesnt seem to work anymore.
Well my problem stand with my TPI engine. I replaced the MAF and the relays for it. It was giving me code 35 or 45 dont remember. Good thing the previous owner had a lifetime replacement for the MAF, got it free with reciept.
My cars stalls in the mornings real bad, i have to drive several miles to school. As i accelarate it shifts then sometime holds the RPMs to much before shfting. And boy does it smell like rotten eggs inside the car. As i accelrate the car gives rpm then lets go as if i let go of the gas pedal.
Also sometime with the car on at WOT the car rpms barely go to like 3000 and stalls out. Im ruuning out of options.
Ive disconected the MAF and the car runs the same no diffrence dunno if the MAF is active, relays click on.
Guys hope you all can help.
Old Mar 3, 2005 | 12:48 PM
SydwayzTA 86's Avatar
Car: 1986 Trans Am
Engine: 5.7L TPI
Re: Tpi Boggs
what kind of fuel pressure are you getting to the fuel rail ?
Old Mar 3, 2005 | 03:18 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Sounds like your catalytic convertor might be compromised. I only say that because of the "rotten egg" smell you mentioned. Could be a host of other things too.
Old Mar 3, 2005 | 06:20 PM
Car: 1986 Trans Am
Engine: 5.7L TPI
thats a good point, try takin the cat off, should be easy.. assuming yours is just bolted on and not welded.
Old Mar 3, 2005 | 09:49 PM
TenochZ's Avatar
Car: 88 Iroc
Engine: 305 tpi
No, Cat new pump giving about 45 to 50 psi. Walbro pump.
Im thinking TPS, but what are the symptoms of a bad TPS?
Im seroiusly thinking going carb, im a carb sports car guy.
My 69 Camaro is running a 406 on a demon 750 hitting about 450hp forged internals. Very expensive
Im thinking a 383 with a 650 dp for this one (iroc) but funds are low right now.
But i still have hope for this TPI
Please help guys.............
Old Mar 4, 2005 | 12:38 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
If you want to check the consistancy of the TPS use your volt meter or scan tool to check the volts. You should be .54 or whatever you have it set to. Then move the throttle open with your hand slowly. You should see the numbers go up smoothly until you hit 4.5 or so. If you see the numbers skip sections then TPS is shot or if you can't reach 4 or so, it needs to be adjusted.
Old Mar 4, 2005 | 11:58 PM
91GTABird's Avatar
Car: 92' RS
Engine: 357
Transmission: TH350
Axle/Gears: 4.10
https://www.thirdgen.org/techbb2/sho...hreadid=281704
my problem
same problem
again
and the last post
stalkier
Dec 6, 2015 11:25 PM
ChaseDale3and8
Sep 1, 2015 01:49 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
