HSR only 13's?
Old Mar 11, 2005 | 11:45 AM
shouup's Avatar
HSR only 13's?
I was on the HSR website and it seems that people with hsr, heads, and cam are hitting 13's a lot of the time. This seems a little slow being that its supposed to be such a good intake. Is there a reason for this? Im looking to get in the 12's and im starting to think carbed is the way to go.
Old Mar 11, 2005 | 01:49 PM
Chrome's Avatar
Car: 92' RS Camaro
13's isn't fast?!
Your not gonna be able to put a carb/HSR/xxxxx intake on and get much faster if you keep the Stock Heads/Cam. Most of the ppl just swap intakes and expect xxx amount of horsepower and it's just not gonna happen.
The L98 heads/cam are design around the TPI system. If you goto a HSR to take advantage of the better intake you need a bigger cam and better flowing heads. Also, TUNING comes with that. Several ppl with heads/cam are not gonna see good times if they only bump the Fuel Pressure up.
You'll be happy w/ the HSR. But plan on doing other mods besides that as well. If not, you'd be better of staying w/ the TPI.
Old Mar 11, 2005 | 03:36 PM
Abubaca's Avatar
I think the LS1 has really raised the bar, and people forget just what it takes to go fast. 13's are pretty darn quick.
...as for the HSR, it's an awesome intake. I love carbs, but my friend, it's old technology. If ya know how to make EFI run, it'll beat you everytime. (apples to apples of course)
...and what's to say those set-ups you saw were done right? Maybe the components weren't matched right. There's a thread on here right now about a guy running low 13s on a bone stock L98.
You won't be sorry if you go with a HSR.
Old Mar 11, 2005 | 05:09 PM
CHEVY_EATER's Avatar
Car: 93 Mustang GT
Engine: 5.0
Yea, it is the same thing with all cars...you can't just throw $$ and parts at the car and it instantly be fast...the right combo and having it run right are a huge part of the equation. A properly running and modded stock car can beat a car with more mods if they are not done right.
Old Mar 11, 2005 | 08:06 PM
shouup's Avatar
so what would AFR195's a matching cam and HSR make you run in the quarter if done right (im assuming all other basic mods such as Throtle body, exhaust, etc.)?
Old Mar 11, 2005 | 08:11 PM
Chrome's Avatar
Car: 92' RS Camaro
Wow, you've went from one end of the spectrum to the other. w/ that setup I imagine with the correct gears/stall and a Tranny that can handle it, add some sticky tires and you'd be in low 12's high 11's.
Old Mar 11, 2005 | 10:39 PM
87350IROC's Avatar
Car: 87' IROC
You must have read his post wrong. He mentioned new heads and cam in his first post. You guys misunderstood him.
Old Mar 12, 2005 | 01:59 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ive got stock tpi and i bet i could hit 12's with anything but the bald street tires ive been racing on.
Old Mar 12, 2005 | 11:41 AM
shouup's Avatar
im talking all motor though
Old Mar 12, 2005 | 12:44 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
you shoulda said that earlier then.
Old Mar 13, 2005 | 04:00 PM
shouup's Avatar
being that i mentioned heads, cam, and intake you should have assumed all motor. I never mentioned nos or a power adder nor did anyone else.
Old Mar 13, 2005 | 04:23 PM
1320 Right Ln.'s Avatar
let's say you do get those AFR heads n' the HSR... the times you run will still depend on exactly which cam you choose. Chassis/suspension set-up, tires, trans/stall/gears will all come into play for determining your times n' speed. So really, it's hard to predict "What will i run if i have blah blah blah." To give you an idea, my car has run a best of 12.61 @ 101.6 mph with a 383, HSR, trickflow heads, and a very mild cam @ 214/220, .452"/.465" on a 110 LSA. 2400 stall converter in a 700R4 w/3.42 rear and 10" slicks. The chassis is pretty well set-up though. I think the car can go faster with the current set-up, but since then a 3000 stall converter has been installed, and a much more agressive cam is being ground down right now by ISKY w/ 226/234, .505"/.530" on 112 LSA. These two changes i hope will bring the car down to the 12.1x or 12.0x range.
Old Mar 13, 2005 | 07:44 PM
vampiroc's Avatar
Car: Z28
I was running low 12s with an HSR, heads and cam. Maybe a stock cam and stock heads with HSR gets you 13s lol.
Old Mar 13, 2005 | 08:28 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
There is a guy on the Stealthram forum with a 383, AFR heads, hot cam, and the HSR system running 11.73 in the quarter on a 2800 stall i do believe with 3.73s.
Old Mar 14, 2005 | 09:15 AM
shawnc16's Avatar
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
You can throw as many parts on the engine you want but if you dont tune your ecm to the new parts its not gonna run as it should. Most of the magazine articles have noted that. Just had to throw that in.
86z89iroc
Oct 5, 2015 01:04 PM
86CamaroDan
Sep 29, 2015 10:08 PM
mike22115
Sep 28, 2015 04:49 AM
BBSDesigns
Sep 22, 2015 03:08 PM
355tpipickup
Sep 4, 2015 05:32 PM
