Who has broken Scat 9000 Crankshafts
Old Mar 24, 2005 | 01:04 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
Im looking at building a 383 with this crank and wondering if it will hold up. Has Anyone broken one? If you did how much power were u making and what were u spining it to?
Are eagle I beam rods any good? who has broke thoughs?
I wont be spining it past 6krpm and thinking about 300-400hp thanks
Old Mar 24, 2005 | 02:52 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
You should have no problem at all making that kind of power with that crank. I'm using the same one and probably making 350-400 at the flywheel if not more.
Old Mar 24, 2005 | 03:30 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I have the eagle version but I'm using forged H beams also. No probs with the crank. I got the rods really cheap, thats why I went with those.
Old Mar 26, 2005 | 03:22 AM
smokefan's Avatar
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
you should be fine with a cast crank around 400 hp. just dont rev it over 6 grand and you should be fine
Old Mar 27, 2005 | 02:06 AM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Scat is the very first company who started to mass produce the after market stroker crank in that late 80's they are cheap in price and strong compared to many other companys out there.
The weak link is going to be your connecting rods or pistons.
Old Mar 27, 2005 | 08:37 AM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I rev mine to 6700 rpm with around 492 hp at the crank. From what I remember those crank are rated at 650 hp NA.
PAT
Old Mar 29, 2005 | 06:20 AM
neat's Avatar
Car: 1991 Corvette
Engine: Bottle fed L98
Transmission: ZF 6 speed
Axle/Gears: D44 IRS/3.92
I had that exact combo in my 1992 vette. Scat cast crank, Eagle I-beams, and probe pistons.
I made 475 RWHP and 620 RWTQ on a 100 shot of juice without any trouble. On engine alone it made 380 RWHP 390 RWTQ. That's well over your goals and it lasted me past 20,000 miles.
Old Mar 29, 2005 | 11:16 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I believe it was a Scat crank Willie broke in his 305.
Old Mar 29, 2005 | 08:24 PM
Vader's Avatar
A well prepared stock cast crank, polished and stress-relieved rods, and a good balance will generally take 450 HP all day long.
If anyone had paid any attention to preparing the Scat or any other cast Chinese crank, it should do as well as stock.
Old Mar 29, 2005 | 08:51 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Willie's wasn't a cast crank, it was an alleged forging.
Old Mar 30, 2005 | 07:39 PM
robsgta's Avatar
Breaking a crank is almost never heard of especially an after market made. It is usually the parts that ride on the crank that give, connecting rods or pistons or a spun bearing is more likely.
Old Mar 30, 2005 | 07:54 PM
robsgta's Avatar
IMO cranks are the least likely part to break unless your spraying or boosting heavy.
sheachopper
Jul 31, 2019 11:27 AM
apie2546
Oct 16, 2016 02:24 PM
no green
Jan 9, 2016 09:22 PM
Reid Fleming
Oct 10, 2015 09:56 PM
LT1Formula
Oct 8, 2015 08:34 PM
