Difference between T/A and Camaro TPI
Old Mar 30, 2005 | 12:44 AM
J-Bru-Ha Z-28's Avatar
Car: '91 Z-28
Ok here is my situation. I have a '91 Z-28 with 350TPI its a daily driver in the summer. I have been looking for another TPI setup to buy so i can work on it at my own pace ie. portmatching and such to the plenum and base. I have found a few TPI setups for sale but they are from a '91 T/A. Would this setup even work for my camaro? If so would i be at a disatvantage, because I have heard that the T/A was rated at less HP due to a differnt intake design. Is this true? Im lookin for all the help i can get.
Old Mar 30, 2005 | 02:10 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
They are indentical engines.
The camaro had more HP because of the twin snorkel air intake system to the throttle body. The firebirds used a air intake/filter system routed from behind the passenger-side headlight.
Old Mar 30, 2005 | 11:00 AM
Car: '91 Z-28
So the TPI parts are all the same, same casting or part #? And so after i would port match everthing and swap them i should see some gains.
Old Mar 30, 2005 | 11:05 AM
1992rs/ss's Avatar
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
they are all the same part number for the same year cars. as the years went on they changed as the system lost the cold start injector, and went from MAF to SD.
Old Mar 30, 2005 | 01:18 PM
Car: '91 Z-28
Alright sounds good. Now I can keep and eye out for a TPI system from a '91 camaro or T/A, it seems like there are lot more T/A systems out there than camaro. Were the production numbers much larger than the camaro that year or just a coincidence?
Old Mar 30, 2005 | 06:51 PM
Jade Grey's Avatar
Engine: 305TPI
GM actually made the 1991 Firebirds for about a year and a half. It is the 1990 models that are rarer because of lower production numbers. Camaro production numbers greatly exceeded Firebirds for any year in the 3rd gen range.
Old Apr 2, 2005 | 03:09 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
2 things to look for are in 91 i think they changed the throttle cable and got rid of the cold start injector. If your are just porting the plenum everything should move over without problems and use your old tb.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Wade787b
Sep 29, 2015 01:15 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
