fuel injector question!!!
Old Mar 30, 2005 | 02:07 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
Can anyone tell me what color the oem fuel injectors are on 89 GTA's with 350's. I am trying to find out if my injectors are stock. A picture would be great, if anyone has one of there fuel injectors on their 89 GTA. I think they are grey, i am away from my car right now so i am not sure. I could not find a part number on them, i have not removed them.
Old Mar 30, 2005 | 03:30 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
black
Old Mar 30, 2005 | 04:10 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
gray injectors are for the 305, 19#
Old Mar 30, 2005 | 05:35 PM
pellmanm's Avatar
Car: 1989 GTA
Would that make a noticable difference? Could they bie for anything else other than a 305? I just bought the car and took it out for a drive and it didnt have that much power above 2500 rpms like my friends stock 87 GTA.
I just bought an adjustabel fuel pressure regulator along with alot of other tune up mods so that should fix it.
Old Mar 31, 2005 | 09:36 AM
pellmanm's Avatar
Car: 1989 GTA
I just talked to someone from cruszinperformance and he told me that the fuel injectors for both 305 and 350 in 1989 were all grey.
Old Mar 31, 2005 | 09:47 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
mine werent.
Old Mar 31, 2005 | 10:56 AM
pellmanm's Avatar
Car: 1989 GTA
(A) 85-86 IROC, T/A, Vette Bosch Pintle injector With a plastic tip
(B) 87-88 IROC, T/A, Vette Bosch Pintle injector With a aluminum tip
(C) 89-92 Camaro, IROC, T/A 89-91 Corvette Multi-Tech (Rodchester) injector. Street & Performance can clean and match your injectors and provide with O-Ring, Tips and performance screens
Check out this link:
http://hotrodlane.cc/Streetstories/choosetpi1.htm
Look at the bottom of the page they show the picture with the grey injectors as 89-92.
Old Mar 31, 2005 | 10:41 PM
88blackgta's Avatar
Car: 88 GTA Notchback
Engine: 355
All 89 through 92 F-bodies were originally equipped from the factory with the Gray and Silver Rochester Multec injectors. 305's and 350's look the same but have different part numbers. They also have the highest failure rate of any injector due to the solenoid coils shorting out.
You would be better off replacing them than trying to have them serviced.
Old Mar 31, 2005 | 11:13 PM
pellmanm's Avatar
Car: 1989 GTA
Yes, i was told the same thing by cruzin performance. I will replace them this summer.
Old Mar 31, 2005 | 11:19 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
I had about four sets of those Multecs... I used them for target practice.
MustangBeater20
Oct 29, 2022 09:20 PM
bryan623
Mar 22, 2021 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
