Isn't Powerful from 2500 and above RPM what could be wrong
Old Mar 28, 2005 | 09:07 PM
pellmanm's Avatar
Car: 1989 GTA
Engine: 383 Fuel Injected
Transmission: Pro-Street 700-R4 by Pro-built
Axle/Gears: Moser 12 bolt w/posi
I just bought a stock 89 Pontiac GTA. Off the line the car seems to have plenty of power, however, above 2500 rpms it doesn't pull like my friends stock 87 GTa, that should have 10 less HP. The exhaust smells a little funny, kinda rich and maybe like a bad converter, but the converter seems fine. The fuel injectors look like they may have been replaced. The guy i bought it from noticed the same problem. The motors sounds fine, no knocking and it revs up fine. Could it just be tune up parts or maybe tps and iac and timing adjustments?
What could be wrong, i plan on replacing the following parts to try to fix the problems and to increase the power.
I have been replacing alot of the tune up parts:
-msd coil,
-msd cap and rotor,
-bosch plugs, and msd wires
-fuel filter and pcv and 02 sensor
-new exhaust system, catco cat, 80 series muffler, and 1 3/4 slp headers.
-bbk adjustable fuel pressure regulator.
-all new hoses and vacuum lines
-custom cold air intake.
Could it be something else?
Old Mar 30, 2005 | 06:16 AM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
i'd look into the fuel injectors and make sure they're the proper size
Old Mar 30, 2005 | 02:27 PM
pellmanm's Avatar
Car: 1989 GTA
What do the color are the stock fuel injectors on an 89 GTA with a 350, does anyone have any pics.
Could it be something else, i doubt the fuel injectors have been replaced, but they do look pretty clean and new looking. They are not black lkine my friends 87 i think the plastic part is grey.
Old Mar 31, 2005 | 10:19 PM
vortec77's Avatar
Car: 86 T/A
Engine: 2000 TPI 5.7L vortec L31
those injectors should be black. Also you dont have a service engine soon light on? no codes?
Old Mar 31, 2005 | 11:12 PM
pellmanm's Avatar
Car: 1989 GTA
No i don't have an SES light on, and i talked to a guy at cruzin performance, and i found a gm article on the stock fuel injectors. For the years of 89-92 they change to a grey colored fuel injector, some were 19lb(305) and some were 33lb(350) but they were all grey from 89-92.
So if it was not my fuel injectors, and my SES light is not on, what else could it be except for tune-up ****?
Old Mar 31, 2005 | 11:15 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
What kind of Bosch plugs? Tested fuel pressure yet? Pulled codes? For the rpm I'd look to the ignition. Since you've done so much, I'd pull the module and get it tested as well.
Old Mar 31, 2005 | 11:16 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Oh, and '89's had those ****ty Multecs, which were grey, and the larger size was 22, not 33.
Old Mar 31, 2005 | 11:33 PM
pellmanm's Avatar
Car: 1989 GTA
Sorry that was a typo i meant 22lb(305)
Can there be any trouble codes without an SES light?
Old Mar 31, 2005 | 11:42 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
22 for the 350. 19 for the 305. I knew what you meant though.
Being on? Yes.
Old Mar 31, 2005 | 11:47 PM
pellmanm's Avatar
Car: 1989 GTA
So there can be a trouble code without the SES lighting up? Do i just check it using the pin method of flashing the SES light to pull the trouble code?
backtothe80s
Sep 5, 2015 12:39 AM
InfinityShade
Aug 22, 2015 08:00 PM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
