airfoil...yey or ney
Old Mar 30, 2005 | 04:48 PM
DanTheMan_smlk's Avatar
http://www.jegs.com/cgi-bin/ncommerc...34&prmenbr=361
anybody have this installed on their camaro? was it worth it? did it really increase power (11.8hp as they say)? include any other helpful info
thanks guys
Old Mar 30, 2005 | 05:09 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
ive always heard they suck, but i bought a used one for 20 bucks, only reason was to help with my nitrous distribution. i never did feel a difference.
Old Mar 30, 2005 | 06:10 PM
brutalform's Avatar
NEY!
Old Mar 30, 2005 | 06:20 PM
TragicPark's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L V8 TPI
I only felt a minor improvement in throttle response when I installed mine. I doubt it gives you any hp improvements, and if it does then it's miniscule. At most it just creates a little better airflow by dividing the air into the throttle body and eliminating that "cave" like area between the throttle plates. Maybe....
~Roger
Old Mar 30, 2005 | 06:34 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I wouldn't give $65 for one. Maybe $30 bucks off ebay at the most. I think I bought mine new from TPIS for $40. I didn't really notice a difference. Some members have actually made their own. You might find such decussions in the search somewhere.
Old Mar 30, 2005 | 06:46 PM
i had a feeling it was bs, but comming from a toyota celica that has NO aftermarket support, i was willing to buy almost anything for a camaro
i dont have a camaro yet...still looking
Old Apr 1, 2005 | 12:14 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Airfoils are going to increase the CFMs by allowing the air to flow smoothly into the plenum. Will you feel the difference? NO. but it does help. MSD ignitions you can't feel the difference but you know what it does and how it help
A lot of little things can make a huge diiference. One thing wont do it by itself.
DanTheMan_smlk
If your still looking for a Z check out southwest regions board
Old Apr 1, 2005 | 09:14 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
[QUOTE]Originally posted by 3GTAs1TA1Z28
[B]Airfoils are going to increase the CFMs by allowing the air to flow smoothly into the plenum. Will you feel the difference? NO. but it does help. MSD ignitions you can't feel the difference but you know what it does and how it help
I totaly agree with 3GTAs1TA1Z28.
There are so many free and cheap mods you can do to a 3rd gen to lead you in the direction of improved over all performance. No one single bolt on is going to plant you back into the back seat like a pro fogger or 3000+ dollar super/turbo charger.
A good rule of thumb on a stock 350 is a .10 improvement in the 1/4 mile per bolt on.
A tenth isnt going to be noticablely felt but it is somthing you can see on a time slip.
Old Apr 2, 2005 | 07:53 PM
BulliTooth's Avatar
Car: 1989 Formula
Axle/Gears: 9 bolt GW6
i read an artical on gm high-tech they got like 6hp(wheel power) on a lt1 motor using a holly airfoils. but they didnt show anything to back it up, caint remeber the issue thow
Old Apr 3, 2005 | 04:56 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
I use one just to cover up the center between the bores, and the TB looks better with the airfoil, throttle plates, and bores polished.
The actual benefit is at very high velocities where the air flow tends to become turbulent without the airfoil.
Old Apr 3, 2005 | 12:06 PM
Vader's Avatar
Which is coincidentally about the velocity that would represent higher RPM airflow through a throttle body - An RPM that the resonance of the runner length of a typical TPI would begin to impede intake flow. So just as an airfoil would become effective, the TPI runners would become restrictive. The net effect is no measurable gain. It makes about as much practical sense as a long duration, high overlap cam lobe in a TPI.
The reason an airfoil can help on a stock TB for an LT1 is that the LT1 has 3" long runners, not 19" long runners.
Unless you have a very rare setup, you're not going to realize anything near 11HP. Save teh money and apply it toward a die grinder that can actually help your intake flow.
Old Apr 3, 2005 | 03:44 PM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Originally posted by Vader
... So just as an airfoil would become effective, the TPI runners would become restrictive. The net effect is no measurable gain...
That's why my emphasis is on looks, not functionality.
Old Apr 3, 2005 | 07:26 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
by the time you have enough power to make a difference with the airfoil, you should be buying a bigger throttle body anyways, and they already have the airfoil molded in.
Old Apr 3, 2005 | 07:46 PM
ok, thank you guys for informing me...i wont get it, its a waste of money
btw...91 RS in the paper, hopefully its a good one and i get it
Old Apr 4, 2005 | 09:44 AM
StreetRoc85 350's Avatar
Car: 88 IROC
Transmission: Pro 5.0 shifted T56
Axle/Gears: 10 bolt 3.73 posi
Hate to rain on your parade but if its a 91RS chances are its a TBI not a TPI so an airfoil is something you wouldnt even have to worry about
Old Apr 4, 2005 | 05:13 PM
yeah, i just realized that yesterday, so im not even gonna call the guy
the search continues......
there is an 85 iroc, but thats just too old for me..too much component wear for me to handle
85camarojunkie
Members Camaros
82
Feb 17, 2011 04:56 PM
mars22
Jun 8, 2005 03:06 AM
a73camaro
Oct 15, 2003 12:01 AM
Rob Gordon
Oct 25, 2000 10:46 PM
