hard starting, dies when i stop
Old Mar 31, 2005 | 10:13 PM
brian88gta's Avatar
Car: 1988 trans am gta
Transmission: t-5
So my car is acting up again. Sometimes the car feels like not starting and the only way to start it is to hit the gas a little. Now the car also stalls when i come to a stop and put the clutch in. Does this sound like it could be a problem with the IAC valve? Or maybe an alternator problem because i notice the volts drop when the car is idels but its not too drastic.
Old Mar 31, 2005 | 11:12 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Your pcv is stuck closed allowing your turbo to pressurize your crankcase enough to stall your motor...
Would help if you told us what we are trying to diagnose huh? (and more symptoms and any diag you've done)
edit: Fat fingers punch pvc. Thanks Tommy.
Old Apr 1, 2005 | 12:02 AM
3GTAs1TA1Z28's Avatar
Car: 85 87 87 91 92
Engine: 305 TPI 350 TPI 350 Carb
Transmission: B/W T-5 and 700R4
Could possibly be your fuel pump mine did the same thing. next time your on the freeway kick it out of gear foot off the gas see if it dies. that was solved in my case with a new fuel pump off course a few days later it went completely out
Old Apr 1, 2005 | 12:31 PM
brian88gta's Avatar
Transmission: t-5
My pvc valve works fine and i dont have a turbo on my car. I tested the fuel pressure and its perfect. I decided to check my air filter and i found a plastic bag blocking the air. I cant believe my car still ran. It also ruined my k&n filter because the suction made the walls of the filter collapse. I havent experienced any stalling, but my car still has a hard time starting when its hot. The car cranks but doesn't want to turn over unless i step on the gas pedel a little bit. I dont have to floor it but i just have to press it a little and it turns over right away. This is fuel injected engine so why would that make it start?
Old Apr 1, 2005 | 02:03 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Facetious
Main Entry: fa·ce·tious
Pronunciation: f&-'sE-sh&s
Function: adjective
Etymology: Middle French facetieux, from facetie jest, from Latin facetia
1 : joking or jesting often inappropriately : WAGGISH <just being facetious>
2 : meant to be humorous or funny : not serious <a facetious remark>
That one apparently went right over your head.
Old Apr 1, 2005 | 03:52 PM
brian88gta's Avatar
Transmission: t-5
my bad, u slipped that one bye me. So do you have any ideas?
Old Apr 2, 2005 | 02:42 PM
brian88gta's Avatar
Transmission: t-5
anyone?
Old Apr 7, 2005 | 07:45 PM
brian88gta's Avatar
Transmission: t-5
Facetious
hey thanks a lot for your help red devil.
Old Apr 7, 2005 | 09:17 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Re: Facetious
Wow, you have one helluva sense of entitlement huh? You must be a lifelong member of the democratic party.
Originally posted by Red Devil
...Would help if you told us what we are trying to diagnose huh? (and more symptoms and any diag you've done)
Must have slipped that one by you to. Didn't realize I was here to do your bidding bitch. You don't have to get all pissy because
1. You apparently can't read well.
2. You don't comprehend what little you can sound out.
3. You can't work on a car.
4. You apparently expect me to help you like you are entitled to it.
5. You are impatient, don't want to pay a mechanic, and are looking for a freebie, and have a fit when you can't get it.
You should have stopped and whacked yourself in the head and asked 'Gee I wonder why no one is answering my questions, they can't smell me...can they?'.
You likely should have re-read your own damn thread before posting that sarcastic horseshat.
And just so you can learn something today, my first response is actually a correct -possible- diagnosis for a turbo car. You've told us you don't have one. Maybe you'd like to tell everyone else now what exactly this poor car is that had it's air filter wrapped in a plastic bag. I hear that's a popular suicide method.
You're not related to Platinum/Kidrcth/Therckid are you?
Tool.
Old Apr 7, 2005 | 11:09 PM
brian88gta's Avatar
Transmission: t-5
damn must be that time of the month. You should try some midol and get some rest because your period is obviously making you moody. Your probably going to write about this thread in your diary tonight before you get your *** torn open by boyfriend. You should change your name to red tampon because i think thats a better fit.
Old Apr 7, 2005 | 11:58 PM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Yah-hooie!! gearhead humor with substance ds fj' kij, ah excuse me I laughed so hard I fell off my chair! If I was a cow I'd be hurting in all 4 stomachs. Freeze - just had a frighten thought - you guys might be serious, nah, encore! encore!
Old Apr 8, 2005 | 03:40 AM
Black Bomber's Avatar
Car: one with wheels
Engine: one with pistons
Transmission: one with gears
Damn Devil, that -was- a tad harsh. I mean yea, he deserved something, but...
brian, you really need to step back and ask yourself why you felt the need to call somoene out like that dude. Really, everyone here is here to help, I hope, but you can't expect anyone to cater to you hand and foot.
As for your answer, look a few threads down, Devil suggested MAF relays for something similar in a MAF car. Maybe you might want to start there since you say everything checks out.
https://www.thirdgen.org/techbb2/sho...hreadid=288803
Old Apr 8, 2005 | 09:00 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
:shrug: A tad harsh? maybe. It struck me the wrong way, particularly since he called me out. Sounds like he's used to 'getting his' every first week of the month.
I hate people who always feel they are entitled to something from someone. It's one of the biggest problems in this country now. No sense of responsibility goes hand in hand with it. Most others would agree. I don't feel there is any place for it on here, and with particularity when it involves me.
Brian, get a dictionary and try and come up with something original, or at least something that surpasses a second grade recess name calling. That was weak. If you are going to call someone out, make sure you have the tools to actually do something.
Oh yes, and maybe next time read through the FAQ and a few threads. You should really begin by pulling your damn codes to see if you have anything there, and then read the tech articles where SURPRISE there is an article that tells you how to set idle air and tps. Wow, who would have thought to help themselves! And then maybe you can start looking at those relays too... if we're talking about a MAF turdgen. I still don't see more info posted.
Old Apr 8, 2005 | 10:04 AM
brian88gta's Avatar
Transmission: t-5
Look i was pissed last night when i read red devil's post. He was harsh and so was I. This is a great site and ill admit i was out of line with my last post.
Old Apr 8, 2005 | 10:11 AM
brian88gta's Avatar
Transmission: t-5
I dont expect anyone to cater to me. I just would have appreciated his input rather than his insults.
Old Apr 8, 2005 | 10:20 AM
Chrome's Avatar
Car: 92' RS Camaro
He asked a question, obviously he is a newbie. I didn't know that being ingnorant about car mechanics automatically makes a person an idiot and not worth anybodies time or gratitude...
Brian,
Try reposting on the Tech/General engine boards and please try to explain alittle more of your problem.
Old Apr 8, 2005 | 10:30 AM
brian88gta's Avatar
Transmission: t-5
Thanks Chrome. I am going to try a couple more tests so that i have some more data to work with. I know that a sensor is probably out of wack because of the bad gas millege. I did take it to a mechanic and they said that my problem was bad injectors and a sticky throttle body. I replaced both of those along with a fuel regulator and I still am only getting aroung 12mpg.
Old Apr 8, 2005 | 11:38 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Fine, that's fair, water under the bridge.
Now pull your codes to see what you have and check the tech article I listed for iac and tps and then check your maf relays.
Old Apr 8, 2005 | 11:49 AM
brian88gta's Avatar
Transmission: t-5
Thanks, ill check that out
Old Apr 8, 2005 | 07:32 PM
kevinc's Avatar
Car: 1982 Z28
And if you're still stuck, go buy a fricking manual or something. Geez.
To the other guy's point, being mechanically-challenged doesn't mean you're stupid. Being unable to connect that need with an attainable result, eg. buying a detailed repair manual, very much does mean you're a few cans short of a 6-pack.
Trashing one of the better helper-outer guys here like Red means you're also lacking the plastic thingy to hold what's left of the 6-pack together.
Old Apr 8, 2005 | 08:43 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Originally posted by Chrome
... I didn't know that being ingnorant about car mechanics automatically makes a person an idiot and not worth anybodies time or gratitude... ...
I missed this. How did you manage those conclusions? I just didn't like getting called out like I'm not doing my 'job' or something. I donate my time here, my name's not Tobey. And Gratitude is typically earned, not something you're likely to earn asking for help.
Aww, gee Kev, that's nice. I'm a helper-outer guy. I was always told I'm just the resident wise-***. Does this mean you like me now?
Old Apr 8, 2005 | 09:00 PM
kevinc's Avatar
Car: 1982 Z28
Aww, gee Kev, that's nice. Does this mean you like me now?
Only if I get to be the tear-your-***-open guy referenced above...
jklein337
Sep 19, 2018 06:23 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
cstrobel65
Aug 15, 2015 10:19 AM
hokis
Aug 9, 2015 03:57 PM
