View Poll Results: Who say yay or ney for building a 335 stroker and being an individual?
YeY!
48.39%
Nay!
16
51.61%
Voters: 31. You may not vote on this poll
335 stroker build-up
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
For all the people pissing on people about being stupid for even thinking about building a 335 stroker. ****ing BLOW IT OUT YA ***!
EVERYONE in there right mind knows that BUILDING A 350 based motor would be a more race type engine, MAYBE SOME JUST want to be a litte individualist and different like myself and build what every the hell they want. AND for the count, I do plan on eventually building a 383 stroker for my Iroc but right know I am still in college so money is tight. I want to through on some heads a cam and a 125 shot of nos for the "bet you cant grab that $100" acceleration.
Some people just try so hard to get everyone else to have the same thoughts that they do.
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I vote nay. I had planned on a 335 for pretty much the entire two years I've had the bird. I got a used stroker crank for 100 bucks, powder metal rods for 60, but when it came time to find 335 pistons, they just never showed up on Ebay. The cheapest place I found the stroker pistons was $250 a set. For the same 250, I got a 350 block freshly machined 30 over, align honed, new freeze plugs and a set of 383 pistons. Even trying to do a 335 cheaper than the "kits" I ended up doing a 383 for cheaper including buying the freshened block... Now I have a 305 block that I got for free sitting on the floor of my garage that I have to get rid of...
Car: 89 Formula
Engine: 355
I see a
coming soon.
Relax, I am sure most guys are just thinking with their wallets and want to see you get the most bang for your buck, if you want a 335 then build it.
coming soon. Relax, I am sure most guys are just thinking with their wallets and want to see you get the most bang for your buck, if you want a 335 then build it.
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Notwithstanding the ignorance of the post, nor your behavior here or in the other thread...
Exactly how is it individualistic when the outward appearance is the same as other SBCs?
If you are tight on cash than you should realize the value that spending another $50 for a 350 core would bring.
Furthermore, I already mentioned, it is not a 'race' thing it is an engineering thing. The shrouding problem doesn't disappear when you stroke it, it becomes more pronounced. You are stuck with the crappy design for that size unless you get a Ford block. Do you read all the posts in your threads, or only react to the ones either opposing your view or that you find are 'putting you down'? There was some good info in that thread.
Then again, it's your money, which is allegedly 'tight'. Maybe you might want to address anymore issues in your other thread>https://www.thirdgen.org/techbb2/sho...hreadid=290134
Car: '87 Iroc-Z
its individualist because you are doing something you want to, NOT what everyone else think you should do
THATS HOW?
THATS HOW?
THATS HOW?
THATS HOW?
If you're not emotionally braced for feedback that doesn't agree with your beliefs, asking for it is a bad idea.
Now go build that bad boy
Car: '87 Iroc-Z
I want feedback but on my actually question which was what do you think of my set-up< Not do you think I should build a 350 or 335.
I asked cuzz obviously I want to see others opinion. I was trying to see it if was worth it because if not i would put 125 hp shot of nos on it and build my 383 stroker which I am building.
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
i'm all about building the 305 to the brink. but if i had to do it all over again, i'd have built something larger. i spent about the same amount of money building my 305 as i would have building a 350. mine is faster than most 305's, and still has potential to be even faster, but to stroke the 305 would be shear stupidity. "different" doesn't win races. power does. you can build a 334 for the same cash as the 383 and the 383 will ALWAYS be faster.
since i have a solid shortblock already, i am going to get as much out of the 305 as possible. but as soon as she blows, 350"+ is going in.
Car: 1991 pontiac GTA, and a1992 pontiac firebird
Engine: 5.7 l98, and a 3.1 for now
Transmission: 700-r4s
Go nuts, no reason why you shouldnt do something different. i my self was going to build a 4.1 stroker out of a 3.8, unfortunatly i am no longer alowed to stor parts cars.....
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
If you want to be individualistic and build a 335, then do it. When your done, show pictures, and talk about your experiences. Until then, people aren't going to show much respect because it feels like we go through this once a week, each time with someone new.
The only problem with a 305 is its bore size. You'll get shrouding problems with any decent heads due to the small bore. Having a 4.0 bore 305 would be a totally different matter.
By the way, I think I missed something. You are asking for opinions on your setup, and I haven't seen any setup listed. All you said was 335.
Guest
Posts: n/a
I suppose if you had a 400 crank and appropriate related parts laying around, it'd be no big deal if you were doing a rebuild. Then again, if you're doing a rebuild, why not rebuild a 350 instead? I've picked up cores for less than $200, for the cost of a rebuild thats not all that significant even for a college student. If you really need a different engine, 305's are dime a dozen. I'll bet you can find a good used motor for a few hundred (I have, twice) and just do that and forget the extra cost involved in 26CI. It wont make that much difference in power for what its worth anyway, port the heads or run a different cam and pick up that power instead.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: '87 Iroc-Z
enginekits.com charges $599 for the stroker kit and only an extra $200 to balance the engine. Their kits don't require machining the block and I can build it myself. That's how.
Car: 1987 IROC-Z
i just pulled my engine from my car. its a 305 from an 87. 62k on it. oil changed every 2500 miles and stuff...could be an awesome core for your 335 if you want it. i went a 14.969 at 90.61 with a 2.067 60' and 2.73s with this engine. PM me if you want it.
Engine: 383 Carb
Transmission: 4L60
Coincidentally, their 383 kit is only $489. Hmmmmm....
Former Sponsor
Car: 1992 Camaro RS
And of course the 383 kit is so much more expensive!!! Good thing the 335 you can build yourself, because the 383 is a completely different animal to build!!!
Wow, haven't taken it apart yet and you already know it doesn't need machining? I take it your engine doesn't wear like everyone elses then?
I really like how you ignore everyones comment when its not convenient to answer. Makes it easier to deal with things huh?
Car: '87 Iroc-Z
it just needs to be bored. I talked to a rep. from that company and he told me that the crank would not need clearance smart guy
Modifying the crank is still cheaper than buying a new crank, unless there is some $400 chinese version I havent seen yet.
Car: '88 IROC convertible
Engine: Freakish 305 TPI
Transmission: Dying 700r4
Axle/Gears: LT1 rear
Car: It was a 90' firebird formula
Engine: It had 357 tbi
Transmission: Was 700r4 auto
Axle/Gears: Was 2.73
if that was the cheapest pistons u've found for a 335 u must not have looked very hard, i found a good set of hyperutectics from speed pro for $120 bucks, and i still have them i was gonna build a 336 for my bird but college does suck the money out of u. and i wanted to build this motor not so much for power but because i didnt want to be like everybody else i wanted somthing different.
if you wanna be like everyone else build a 350
Car: 1983 G20 Chevy
Transmission: 4L60
I would build it as it would be a punchy street engine. A 335 can make more torque than a 350.
Engine: 383 Carb
Transmission: 4L60
Chevykid810
Sep 28, 2015 12:57 PM
