Back firing with blue flame
Old Apr 25, 2005 | 11:39 AM
350tpifiero's Avatar
Car: 87 fiero
Engine: 1990 350tpi
Transmission: stock fiero
I have a 1990 TPI motor that back fired a couple days ago. I was in third gear and getting ready to shift into 4th when the car back fired, at the same time a blue flame came out of the tail pipe. Since then my car seems to be luggish when you give it gas and looses horse power. Almost like you have lost a spark in on of the cyclinders.
I've recently had my rockers changed to roller tip ones. I was told that this issue could be related to a value not closing or opening properly. Any truth to this?
Any help with this issue would be greatly appreiciated.
Thanks, Bobby
Old Apr 26, 2005 | 11:06 PM
sleeeper91's Avatar
Car: 91 rs with ls1
Engine: ls1
Transmission: t56
bad rocker? posibly.
Old Apr 26, 2005 | 11:08 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
If your valves are too tight you'll be dumping fuel into the exhaust which could explain your backfire. Adjust the valves with the engine running if you didnt before and Let us know how it goes.
Old Apr 27, 2005 | 10:40 AM
Car: 87 fiero
Engine: 1990 350tpi
Thanks for the help I'll try and adjust the rockers
Old Apr 27, 2005 | 12:16 PM
firebirdjones's Avatar
flames
That would be great for "tailgaters" I can imagine the look on the persons face behind you. Sorry I just couldn't resist, Larry.
Golfvette
Aug 24, 2015 06:35 PM
Linson
Aug 21, 2015 02:12 PM
justin57
Aug 20, 2015 07:05 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
