code 36
Old Apr 28, 2005 | 02:00 AM
87 Iroc G92's Avatar
Car: 87 Iroc G92
Transmission: t-5
code 36
i'm having this problem in the esc circuit (165 ecm)... can't figure it out. code 36 "missing reference pulses in esc circuit".
i've replaced the pickup, dist. module, knock sensor, knock sensor module, tried another computer and chip, tested all the wires for continuity and proper voltage and grounds. keeps popping code 36. The car is driveable, but lacking power, and pings and feels like it's missing under hard acceleration, it's driving me nuts and i can't figure it out, any shop i take it to will probably only replace everything I have already replaced.
any help is much appreciated
thanks
Old Apr 28, 2005 | 06:43 AM
yupitsme's Avatar
Car: '88 gta
Engine: 5.7 ltre 350
just guesing but check the in jectors i got a simalier problem,not a code 36,but a code 34(mass air flow sensor) it turned out that 1 injector has turned bad,replaced all of them to be sure, solved my code problem
Old Apr 28, 2005 | 01:36 PM
Car: 87 Iroc G92
Transmission: t-5
thanks
I'll try that, i have 2 extra sets of injectors, so I'll give that a shot
Old Apr 28, 2005 | 02:04 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
Transmission: corvette 4+3
Dont know where your getting your info, but if your sure you have a 165 ECM and a code 36 this is what you should be checking. This is from a factory repair manual.
Old Apr 28, 2005 | 02:05 PM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
And this.
Old Apr 28, 2005 | 06:37 PM
yupitsme's Avatar
Car: '88 gta
the info i gave him is from experince 884+3 ,i had the same problem,i changed all the relays for the code 34,still nothing.then i pulled the plugs off the injectors to see if any one of them was not working, it turned out that one injector was bad.and it solved my problem by replacing the injector. people tend to forget that some times mechincal problems trigger codes that has gotten nothing to do with it,but he has code 36(mas air flow)it could be a relay or n injector like i said,sorry don't mean to put down 884+3
Old Apr 28, 2005 | 07:23 PM
83Firebird420's Avatar
Car: 87 GTA 120,000k, 90 CRX Si
Engine: 5.7 TPI, 1.6L 16 valve SOHC
Transmission: 700r4, 5spd std
i scanned my comp the other day, got a maf problem, i took the one outa my 305 havent drivin it much since i replaced it (no problems) but when the car did f-up it was very noticable hopefully the different maf fixed the problem...atleast now i know if the problem persists i should look into some fuel injectors
Old Apr 30, 2005 | 01:08 AM
884+3's Avatar
Car: 88 irocz
Engine: b2l 350
N/M
Old Jan 1, 2007 | 06:00 PM
Car: 87 Iroc G92
Transmission: t-5
injectors
i posted this a while ago and have since solved by trial and error. after returning to this page i noticed that several of you guessed it off top the problem was faulty #1 injector, thanks for all the replies had i looked here sooner i would have saved a lot of money. thanks for the help you guys make the wheels turn
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
