Hypertech question
Old Apr 28, 2005 | 12:56 PM
formula1988's Avatar
Car: 1988 forumla 350
Engine: l98 350 tpi
Transmission: 700r4 2100 stall
Hypertech question
14.755@92.96mph With girlfriend in my 1988 firebird 350
I have already baught the cooling fan switch from hypertech.
If i get the computer chip and the thermostat and with out anyone in my car do you think it would be possible for a 14.4?
I have only dragged once and that was yesterday i am going again this weekend and im going to get the computer chip and thermostat. Do you think hypertech stuff will improve my times?
Old Apr 28, 2005 | 08:47 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Not a chance it will improve your times.
I actually slowed down by 2 tenths in the 1/4 mile with the hypercrap chip
Old Apr 28, 2005 | 09:00 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I think you would probably be better off spending the money on something else. What other mods have you done to your car? Were in Indiana you live? I'm in southern indiana, jeffersonville.
Old Apr 29, 2005 | 12:35 PM
Engine: l98 350 tpi
I live in Albany, It is real close to muncie, I've lived here for 3 years. Before that i lived in cookeville Tn. And i was born in sebring Fl. The only thing done to it is exhaust. Not cat. I wont buy the hypertech. I got a cold air intake instead. I'm saving up for a adjustable fuel pressure regulator next. I have 200$. Ill wait till next week to get that.
Old Apr 29, 2005 | 12:37 PM
AZ406TPI's Avatar
Car: 1986 IROC-Z/28
Engine: 406 CID SBC
Transmission: 700R4 A4
hypertech sucks ***... just get on a dyno and see what u need 2 change and either get a new chip or flash urs.
Old Apr 29, 2005 | 01:53 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
No real point for a fuel pressure regulator if you only have exhaust done.Fuel pressure does not even need to be adjusted with full intake and exhaust.Only when heads and radical cams are added.
Old Apr 29, 2005 | 03:39 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
From what I've heard you can just bump your timing up a few degrees and that's pretty much all the hypertech does for you.
I have a magazine article somewhere with a Power Resource chip in a 3rd gen F-body taking a few tenths off in the 1/4 mile. Either way eventually going fast will get in your blood and you'll mod the car past the point of using an off the shelf chip.
I vote to save the cash and dump it into something decent, such as SFCs, LCA brackets, or LCAs if you're having problems with traction.
It has been shown there is a little improvement from a AFPR, but if you search on here you can make your own at a fraction of the cost of a new unit from a catalog. You might consider other free likes the TB coolant bypass, even the small things add up eventually. I picked up 2 mph on my G-tech (back to back) testing using a home-made cold air scoop with dryer hose ran to the filter canister. Course that might not be such a good idea since you do have MAF don't want that getting wet.
I also like the other little mods like a $60 wonderbar that improves the overall handling of the car.
Old May 1, 2005 | 08:54 PM
Engine: l98 350 tpi
http://www.cardomain.com/memberpage/781526/1
There are pictures of my car.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
