Throttle body ?
Old Apr 28, 2005 | 04:54 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Throttle body ?
My accel TB has no spot on the bottom to plug in the vaccum hose. Where should I plug this in at?
Old Apr 29, 2005 | 09:38 PM
Vader's Avatar
That is the only timed port on the TB, and the only one appropriate for the EVAP purge and EGR solenoid source.
Old Apr 30, 2005 | 01:07 AM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Thanks for the help Vader but what do I do. That plug is not built on to the TB. What are my options?
Old Apr 30, 2005 | 11:33 AM
Vader's Avatar
Options?
Call accel and inform then that they "forgot something" on their replacement TB;
Drill a 0.050" hole in the stock location just behind the throttle plates, then drill a larger hole to accomodate a press fit tube, and install your own fitting;
Install a factory TB;
Eliminate EVAP and EGR.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
