what you think about cam
Old May 1, 2005 | 04:33 PM
KamikazeIroccy's Avatar
Car: '87 Iroc-Z
Engine: 355cid Cam'd
Transmission: T5 Manual
Axle/Gears: Stock 9 Bolt
Here it is:
350 engine bored .030 over to 355ci
Flattop pistons with 10:1 compression
Crane hydraulic roller compucam-.452/.465"lift- 270/276 duration
Crane adjustable fuel pressure regulator
Cloyes double roller timing chain
52mm throttle body with TPS enhancer
Edelbrock E-tec 200 heads
Nitrous works kit jetted to 125hp!
Edelbrock TES headers with universal 3" catalytic converter.
Crane Hi-6 ignition with rev limiter, Fireball coil, and adjustable timing box with variable 5 degrees advance and retard range, Accel wires.
Turbo 350 trans with 2000 stall and stage 3 shift kit. Has a tailshaft spacer to retain stock driveshaft.
Borg Warner 9 bolt 7.75 inch POSI rear end with a 2.77 gear.
160 degree fan switch
Grant steering wheel
Power windows, locks, mirrors, and seats.
T-Tops and leather bag
16 inch aluminum Iroc rims-245-50R16 tire size
4 wheel disc brakes
Newer radiator, starter, alternator and IAC valve
Chrome centerbolt valve covers and oil pan
Melling high volume oil pump
Old May 2, 2005 | 09:26 AM
305PhoenixAm's Avatar
Car: 85 Trans Am
Engine: 383 TPI (Yes, TPI. Not for long though)
Going to be hard to get that thing to start without heads.
Old May 2, 2005 | 09:35 AM
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Re: what you think about cam
At least it will look good with the chrome valve covers, covering up the pistons.
Old May 2, 2005 | 09:39 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I was wondering how he planned on getting 10:1 w/ no heads. But now that you pointed out the valve covers, it's obvious. I take it he milled the covers down and used a thinner gasket. probably ported out the PCV hole to make it flow better too. Should be a sreamer.
Old May 3, 2005 | 06:40 AM
cutnsick's Avatar
Car: 88 GTA Pontiac right hand drive
Engine: 350 CI
sorry ive missed something here, I thought E-Tec 200's were heads.
Old May 5, 2005 | 08:36 AM
Car: '87 Iroc-Z
they are dude. Just dumb people
Old May 5, 2005 | 08:44 AM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
is that lift at the tappet or with 1.5ers? I would go for more lift with Etecs. also I am not used to advertized duration but I would think you would want at least 212 at .05 lift for a tpi with that much head. and definately go with the stealth ram cause a stock TPI wont do this much justice. also forget the tps enhancer (junk) and learn to burn your own chips -- youll have to with a cam big enough to warrant those heads.
Old May 5, 2005 | 10:06 AM
Car: 85 Trans Am
Easy to say that after you edit the post to correct your mistake..
Old May 5, 2005 | 01:22 PM
Car: '87 Iroc-Z
HAHA!
have a sense of humor
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
