how to use stainless braded hose in place of factory rubber fuel hose
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
i need to know what part number adapters i need to use from aeromotive to adapt stainless braded hose in place of the factory rubber hose that goes from the fuel lines on the frame rail to the hard lines off the fuel rail. please help me out.
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
Hey, I pretty sure you are going to need some tube sleeves and tube nuts for the hard lines from the frame talk to aeromotive for the actuall part numbers, but fro mthe rails to the stainless you are going to need some adapters. Look in summit at teh TPI/LS1 section and you will see that Accel sells a set of two, for the two different sizes for something liek 40 bucks. Not too bad but not a steal.
Brett
Brett
Pure Choice Performance Plumbing Part #5640. Part #5640 Picture
Car: 1999 Z28
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Originally posted by Abubaca
IS that a direct bolt on? I've looked at doing something like that too.
I haven't used it myself (not yet anyway...been lazy). The last communique I had with them, yes it's a direct bolt on and replaces the lines from the fuel rail to the hard lines on the body. I forget the pricing though.
1992rs/ss
Jan 31, 2025 05:10 PM
1992 Trans Am
May 10, 2023 07:19 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
