BlackRob91 formula woes
Old May 9, 2005 | 01:51 PM
Calico's Avatar
Car: 1985 Buick Regal T
Engine: 87 3.8 turbo/lc2 drive train
Transmission: 200r4brf
Old May 29, 2005 | 09:24 AM
Vader's Avatar
Tuning? What cam? 3.73s behind a TPI?
Old Jun 6, 2005 | 04:31 PM
Calico's Avatar
has a stock cam and, no tuning and yes 3.73s
Old Jun 9, 2005 | 07:48 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i would look into getting the ignition all straightened up and make sure the timing and stuff are all correct.
then look into tunning for those 24lb injectors and runners... i think your better off with the stocker 22 lb injectors and run abit more PSI of fuel from a adjustable regulator. with just runners and nothing much else, it shouldnt be running that slow and have much problems. i think the injectors could be a problem right now.
how old is the 355 bottom end? all the cylinders in good condition? compression test/leakdown test it?
Old Jun 13, 2005 | 12:09 AM
Calico's Avatar
Old Jun 13, 2005 | 12:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i shift mine at 4500-4800rpms sometimes.... but i try to concentrate on 4500-4600rpms. peak power in the L98's is at 4400-4500rpms
that ticking noise....does it come from around the headers? could be a loose bolt and cause an exhaust leak
Linson
Oct 24, 2025 02:00 PM
okfoz
Oct 13, 2015 02:19 PM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
