SLP runners
Old May 17, 2005 | 06:43 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
SLP runners
I got a set really cheap so Im going to put them on. Are they a direct bolt in or do I need to modify the SLP runners in anyway?
I just want to be able to remove and replace but will the fit correctly? or are some bolt holes not going to line up or something else?
thanks
Old May 17, 2005 | 09:45 PM
OK, I did a search and found the answer to my question. sorry..
another question, the verdict on the runners with a 305 is kinda split and more in favor of the 350...but looking at the mods that I have do you think I will benefit with putting the runners on...if not then I might just sell them.
I dont want to go thru the trouble of putting them in if I will see no gain..
thanks
Old May 17, 2005 | 11:13 PM
GOY's Avatar
GOY
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
Most people I think would say to stick with a more stock type runner if you do swap them, something like edelbrock's or best yet AS&M, especially for a 305. Personally, I'd swap them on and see. Doing a runner swap seems pretty straight forward.
If, in the event you do swap them and don't like them, let me know... maybe I can take them off your hands
Old May 18, 2005 | 01:38 AM
norcalz28's Avatar
Car: 1989 Camaro IROC-Z
Engine: ZZZ# 0607 of 1200 produced
Transmission: Pro-Built 700R4/Vig.2400
Axle/Gears: 3.27 BW 9 Bolt PBR Disc
you are definitely going to notice a little less low-end. I did.
Old May 18, 2005 | 08:38 AM
such as? how much? how can you tell? I lost enough when I put the LT1 cam in and dont want to lose any more. THe stall gave it all back to me though...
Old May 18, 2005 | 08:55 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
You only lose about 10-15 ft/lbs. If you think about it, you will notice a very slight lag, not nearly as much as you lost with that LT1 cam, however, you will lose a little.
Old May 18, 2005 | 10:02 AM
SO would you say I go ahead and put them on? The stall should help out what tq I loose if any. Some dont lose at all...
Old May 18, 2005 | 10:22 AM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Just put them on. Alone you probably won't deel any difference in the butt dyno... in your head on the other hand...
Old May 18, 2005 | 10:27 AM
GOY's Avatar
GOY
Like I said before, it's a pretty straight forward job, just give them a try. What do you have to lose, a set of gaskets?
Old May 18, 2005 | 11:12 AM
norcalz28's Avatar
Well I did mine at the same time I installed headers, a catback and a few other things, and I definitely noticed a little less low end in granny driving around town. From light to light. If I get on it the car still won't hookup, so its not like I lost low end all together or something. I am interested to see the dyno results from my stock baseline and now. It wont hurt performance in the way you might be thinking. But I tend to over analyze everything on my car and I feel and hear every little noise and change that happens.
Will
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
