Enlarging Plenum At Throttlebody
Old May 23, 2005 | 06:38 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
i have a 58mm tb for my stealthram and will need to enlarge the opening on the plenum for the 58mm to work properly. instead of enlarging the holes cant i just cut out the middle part of the plenum and make a large open oval??? will this hurt anything, i know it wont help but i want to make sure it wont hurt
Old May 23, 2005 | 07:01 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
I ran one like that on my car with the stock TB, noticed absolutely no difference in performance or idle quality. I needed a spare while I poslished mine, still have it around somewhere I think, If I come across it, I'll post a pic.
Old May 23, 2005 | 08:02 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
cool, just needed some reassurance. i pic still would be cool!
Old May 23, 2005 | 08:09 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Edit: You are correct the Superram comes with 58mm openings. My misread. Allen
Old May 23, 2005 | 08:34 PM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Funny....my 58mm BBK bolted onto my StealthRam and matched up almost perfectly. I had to trim the Fel-Pro TB gasket out to match the bore though.
toronto formula
19
Oct 6, 2015 12:27 PM
italiano67
Sep 22, 2015 08:42 AM
Linson
Sep 21, 2015 01:08 PM
