Popping through throttle body
Old May 22, 2005 | 09:16 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
I am gong crazy trying to figure this out. I have a popping/knocking sounds coming from my throttle body when the engine is under load. Only under load, if i bring the rpms up slow, i get now popping. If i rap the gas, the noise is there.
Here is what i have done so far.
New plugs, wires, iac motor, check fuel pressure, re-did all vacuum, re-checked timing(car seems to idle/run best at 0 degress,L98)
The motor is a 355 with a mild cam, headers and head work. I have a chip tuned for injector constant.
I need help, i am not sure what else to check.
Old May 22, 2005 | 10:01 AM
Don 79 TA's Avatar
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
double check you plug connections and firing order on the cap
1 8 4 3 5 6 7 2
and maybe check your timing too (disconnect the brown/black wire)
Old May 22, 2005 | 11:03 AM
TheGreatJ's Avatar
Car: 91Z, 91RS, '84 Jimmy
Engine: L98, 355, L98
Transmission: 700R, T56, 700R4
Only when it's under a load? Could be detonation. Pull a plug or two and see what they look like. If the ceramic is chipped/pitted then you definitely have a detonation problem.
Does your chip still have the stock fuel and timing tables or have they been modified as well? Head work will make a huge difference in the airflow characteristics of an engine.
Also, base timing for a TPI car should be 6 degress, unless it's programmed otherwise in the chip.
edit: Don you have your 6 and your 5 backwards. It's 1-8-4-3-6-5-7-2 for a SBC.
Old May 22, 2005 | 11:50 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
does the motor seem to idle in gear as it did before the noise started? no misfire? does it run any different now than before?
if you can find no other problems, a sharp rhythmic pop under a load that increases speed with engine speed & intensity with throttle opening coming from the TB could be caused by an exhaust valve not opening because of a problem with, 1, a rocker arm, 2, a push rod, 3, a lifter, 4, a flat cam lobe.
not near as sharp sounding as an exhaust valve not opening is an intake valve not closing. which could be caused by 1, a rocker arm, 2, valve spring, 3 a stuck valve, 4, a lifter.
you would need to pull the valve covers & check each rocker arm, push rod, & valve spring, for a valve not opening you would need to watch the rocker arms with the motor running.
Old May 22, 2005 | 04:13 PM
AT9305RS's Avatar
Car: 91 Bird
Engine: 3.1 w00t
Transmission: 7hundo
Axle/Gears: bent
I have seen the valvetrain move freely when running. Everything seems ok there.
Old May 23, 2005 | 09:26 PM
9D1BURD's Avatar
Car: 1997 Z28
ttt
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
