New problem, more confused than ever
Old May 26, 2005 | 09:23 AM
9D1BURD's Avatar
Moderator/TGO Supporter
Car: 1997 Z28
Okay, some of you may know the saga of mine regarding the popping through my throttle body.
Well, i figured out that when i unplugged the #4 injector, the idle did no change, and the popping was gone.
So i did the obvious, i threw a set of new 24 pound svos on there.
It does the same darn thing, pops with that cylinder plugged in, and makes no difference in idle with it unplugged.
I moved around the injector wires to check those, same thing.
Could i have a valve hung open?
Old May 26, 2005 | 09:28 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
A stuck/failed lifter can cause that too. I'd run a compression check on that cylinder, and probably try to adjust that rocker arm. Hope it's not a ring/valve problem.....
I'd also ohm out that injector, could be a bad one but that's not too likely that it would sit on the same cylinder as a previous bad injector (too coincidental). But I'd still check the easier stuff before pulling the heads....
Old May 26, 2005 | 12:15 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
in addition to what vernw said, you could also have a broken valve spring on the intake valve, what i would lean more toward is something wrong with the exhaust valve, a loose rocker arm, a broken rocker arm, bent push rod or a flat cam lobe.
Old May 26, 2005 | 12:38 PM
9D1BURD's Avatar
Car: 1997 Z28
well, the valvetrain appears to move freely when i ran the car with the cover off. Everything looks in order inside there.
I am going to start looking down the spark avenue
Old May 26, 2005 | 06:07 PM
9D1BURD's Avatar
Car: 1997 Z28
ttt
Old May 26, 2005 | 08:56 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Swap that plug wire out for a nother one and put that one in its place.
My Camaro was poping from the engine, and it was the wires. They visually looked fine. No burns etc.
Old May 26, 2005 | 08:59 PM
9D1BURD's Avatar
Car: 1997 Z28
i have tried multiple wires on that cylinder.
I checked the valve lash tonight, everything seems to bew in order there.
Old May 27, 2005 | 12:24 PM
vernw's Avatar
Have you checked the compression on that cylinder?
Old May 29, 2005 | 08:30 AM
CHEVYINSIDE's Avatar
Car: 1988 CAMARO
Engine: 5.7 TPI
i had mine blew a headgasket i t made a ticking sound and when you desconected the cylinder it was lessened but still there sounded almost lkie a pressure leak. anyways you could hear it come throught the intake . it crossed the two middle cylinders so it still ran and ilded ok but had a miss. hope this helps
Old May 29, 2005 | 08:55 AM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
i would do a leak down test. the test will tell you if the valves are sealing correctly, also tell you the condition of the cylinder, rings, and gasket. From what u are describing sounds like you have a bad, or leaking intake valve. How many miles on her?
Old May 29, 2005 | 07:05 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
Sounds to me like one of your valves isnt sealing or seating correctly could be a burnt valve.(detonation)
If you do have a burnt valve that would explain the popping inside your intake. The cylinder comes up on the compression stroke and the air isnt being sealed in the cylinder and gets pushed back up into your intake.
Do you smell any gasoline fumes in your oil ??
Old Jun 4, 2005 | 09:19 PM
9D1BURD's Avatar
Car: 1997 Z28
100 miles on the new motor.
Old Jun 5, 2005 | 04:57 PM
robsgta's Avatar
Have you performed a compression check yet ? Or taken a look at your plugs ?
Old Jun 6, 2005 | 10:03 AM
dyeager535's Avatar
Car: Which one?
Engine: 355
Transmission: 465
You've also run the motor with a noid light connected to that injector connector to make sure it's not a problem with the injector wiring?
RazorN8
Jan 7, 2022 11:44 AM
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
Jorlain
Oct 8, 2015 01:57 AM
greenyone
Sep 2, 2015 03:39 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
