89 iroc 350tpi, wont reatart when hot,
Ive got an 89 iroc 350tpi , it will start up when cold, but wont start when hot. Its not Vats related since i took that out and have never had a problem with it. I have changed the comp, and the dist just to check, but still does the same thing. anybody have any ideas?
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
You replaced the whole distributor and it still won't start when hot? That's strange because the ignition module controls spark and fuel while cranking, not the computer. That's usually fixes no start 99% of the time. Do you happen to have a MSD or other aftermarket ignition management box installed? If so disconnect it or bypass it during a time when it won't start.
You'll have to start a little troubleshooting otherwise to see what you're missing, spark or fuel. To test fuel disconnect any injector connector, using a test light across both wires see if the light will flash while cranking engine. Do not ground the test light, go across the two wires on the injector connector.
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Dirty or worn/ leaking injectors, try some GM injector cleaner, part #: 12345515
Try flooring the gaspedal when starting hot, if this helps, your injectors are worn.
The car will crank, and has spark, and when its hot it will start if u spray with starting fluid, and then continue to run, other then that it wont start again. untill you shoot more starting fluid. What should the fuel pressure be at idle?noid light on injector blinks bright, car will start, noid light after hot blinks dim, car wont start
Engine: 4.0L
Stay away from parts store ignition modules, they are junk. Use only AC Delco ignition modules and you will be much happier.
Car: 1989 IROC Z-28
Engine: L98 350--modified
Transmission: 700 R4--modified
Axle/Gears: 4:10 Posi
I think fuel pressure should be around 40 + or -. If this were a non computer car, I would be suspecting low fuel pressure and when it warms up , it could be vapor locking--the starter fluid makes that go away, and will continue to run, but when U shut it off, it vapor locks again.
Car: 87 IROC
Engine: 406 sbc with Trick Flow heads, Hook
Transmission: Pro built 700R4
Axle/Gears: waiting on a new rear!!!!
I just had that EXACT SAME PROBLEM! The car would start when its cold but will not crank when hot. I got a new distributer, battery, starter, new coil, plugs and wires. An it still wouldn't crank when hot. Then my uncle suggested get a stronger ground cable. So I went to autozone paid 9.99 for a 2G ground cable, stock cables are 4G. Once I replaced it the car will fire right up everytime hot or cold!
Now I just got to find out why it wont stay cranked when I put it in drive!!
Engine: 4.0L
Originally posted by lilbowilson
I just had that EXACT SAME PROBLEM! The car would start when its cold but will not crank when hot. ........
Engine: 4.0L
john- i put in a brand new dist, still did it
zap- fuel injected cars cant vapor lock, but im gonna check the fuel pressure as stated. thinkin maybe the pump is on the way out
You don't need to change the whole distributor either to replace the ignition module, it is easily replaced with distributor in.
EFI cars can't vapor lock. Your pump could be going bad but I doubt it from your description. Since the noid light was nice and bright when cold and very dim when hot that leads directly to the distributor and it's module. Remember about the heat compound grease I told you about under the module? It's CRITICAL to the life of the module. Without the grease even a good module will fail immediately.
If the fuel pump was bad it wouldn't continue to run after "jump starting" it with starting fluid.
Car: 1989 Iroc
Engine: 5.7
Transmission: TH700R4
Did you check the resistance on your injectors?
My '89 5.7, would start up cold, as soon as i got somewhere would just refuse to start. Little shot of fluid, start right up and act like nothing was wrong. Actually.. this is how i got the car.. guy couldn't figure out how to keep it running. I did a little sleuthing, and checked the injectors with my digital multi-meter... found that two of the injectors were bad. Put some new SVO injectors in, and a adjustable fuel pressure reg (did the reg just because i was there), all better. Car ran ok with the new injectors, but i had a chip burned for the new ones to get past NJ emissions at the time.
IF i remember correctly... bad injectors are common on the '89 cars.
Something to think about...
Car: 1989 IROC Z-28
Originally posted by robsgta
keep us posted
Rob
keep us posted
Rob
Hey Rob--U gonna make the Hou. Summer Meet?
1989formula5.7l
Aug 15, 2015 11:35 AM
mustangman65_79
Aug 11, 2015 03:17 PM
