TBI-TPI conversion help!
Old Jun 7, 2005 | 12:49 AM
OutRacin's Avatar
Got a few questions If anyone wants to take a stab at em.
This is being done to an 88 formula 5.0 TBI
I was told TBI heads will work with a TPI intake, Is it a big hp/tq difference between the two or is it negligible? Any idea on the #'s?
Will a TBI ecm run a TPI providing i swap the two plug injector harness with a 9 plug TPI injector harness, and if so is it simply unplugging the old and plugging in the new?
I know a TPI requires a bigger fuel pump from a TBI setup. i have changed pumps in 3rd gens before and its a royale pain in the A**. Can i run an external pump like a T-rex, or do i need something bigger?
What is the recommended puel pressure for a TPI?
Do i need to change The throttle cable and tranny kick down cable or will the TBI ones work?
Im trying to make this a ONE night swap start to finish so any advice or "tricks of the trade" is greatly appreciated beyond the questions above
Old Jun 7, 2005 | 09:07 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
You need to read this first, then ask questions.
https://www.thirdgen.org/newdesign/tech/tbitotpi.shtml
Old Jun 7, 2005 | 10:53 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
The heads will work, you'll loose HP as compared to the TPI heads. Maybe something in the 10-20HP range...assuming stock for stock swap. Torque curve will definitely be lower as well.
TBI ECM doesn't have the correct drivers for the TPI injectors (least I was told this on the DIY_PROM forum a year or so back.
Yes, TPI requires a different pump...about a60 PSI pump (TBI is in the 15 PSI range).
Unsure on the cables, etc. There is a tech article detailing a TBI to TPI swap on the main page, might be worth a look.
I seriously doubt you be doing a one-nighter...unless you have a TV slot with Chip Foose as the project manager
Old Jun 7, 2005 | 11:14 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Throttle cable- yes.....not sure on the tranny cable.......one night swap- no
Old Jun 8, 2005 | 11:35 AM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
Transmission: Borg Warner 6 spd
You need to change the tranny cable as well, the TBI one is shorter.
Your fuel pressure should be set at 43.5 psi, but yes you can use an external pump.
Your doing this at night? You know what happens at night time right? Your going to drop bolts into every uncovered hole in your engine. Don't ask why, it just happens that way.
Old Jun 10, 2005 | 11:09 PM
OutRacin's Avatar
Thanks guys, i plan to do it on a saturday afternoon into the night, its me and a buddy doing it. he has a well lit shop with all air tools and a lift. I hope its a 1 day project to say the least
Old Jun 12, 2005 | 01:52 PM
Pat Hall's Avatar
Not trying to hack on you dude, but it sounds like you need to do a lot more research before attempting your swap. None of your cables will work on the tpi (throttle, TV, cruise) as they are all longer than the TBI cables. Also, if your tpi is 89 or newer, the throttle cable it uses has a completely different end on it. You can use the TBI engine harness, but you have to do some repinning and use some different connectors in a couple of places. It's easier to just get the correct harness. The TBI ecm won't work with TPI period. I guess, in short, what I'm trying to say is you ought to do a lot more reading in the tech articles on this site and round up all the parts you're going to need for the complete changeover, or you're going to be without a running car for a looong time.
Old Jun 13, 2005 | 12:35 AM
OutRacin's Avatar
its a spare car so if its not done asap its all good, lots of people been tellin me different stuff. i pretty much got it under controll, people were tellin me i could use the stuff stated above and i came on here to check if they were right or not
Linson
Oct 24, 2025 02:00 PM
2012sergen11
Oct 13, 2015 07:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
