car running like crap
Old Jun 7, 2005 | 01:53 PM
lesser85's Avatar
Car: 85 Z28
car running like crap @ idle
Okay, My 305 has been re-built 2 years ago and many parts were repalced as part of the re-build. All sensors are new and correctly set including the IAC and TPS. The only original parts are the MAF and the EGR valve. Besides the warm start up idle issue I mentioned in a previous post, my car just seems to be running weak. The idle is rough, gas mileage is suffering and the rpms seem to remain high after I take my foot off the gas. This is making the car a challenge to drive. I recently tuned it up and set the timing @ 10-12 degrees BTDC. This helped, but it still sucks. What should I try next?
Old Jun 12, 2005 | 10:08 AM
Vader's Avatar
What, specifically, did you do as part of the tune-up?
Old Jun 14, 2005 | 01:05 PM
lesser85's Avatar
Car: 85 Z28
Plugs, cap, rotor, accel 8mm super stock wires, cleaned throttle body, set timing to 10 degrees BTCD
Old Jun 14, 2005 | 04:14 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
Start by reading my answer to your idle problem post, follow through on those recomendations and then lower your timing to 6*and all should be fine.....
You should run hard and idle fine. BTW, the 52MM TB is a little large for a stock 305...... It does eliminate the 3rd gear bog in an '85 350 car.
One last thing to consider, using the IAC reset instruction on the tech pages, reset your base idle speed by adjusting your TB opening, readjust your TPS afterward because it will change if you adjust the amount of opening.
Old Jun 16, 2005 | 01:26 PM
lesser85's Avatar
Car: 85 Z28
I have tried the timing @ 6 degrees. This makes my car run even worse than it does now. I also reset minumun idle speed and tps voltage only days ago. I have also tried clearing the ECU's memory to fix this along with my startup idle problem mentioned in other posts. I have had no luck. The larger throttle body didn't seem to make things worse, and it seems to function well with the 10:1 compression ratio pistons, world products heads, and summit tpi cam. Setting the timing @ 6 degrees makes the car bog something horrible and greatly decreases acceleration.
Anyone have any other ideas???????
Old Jun 16, 2005 | 01:35 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
What prom/computer tune are you running? Hopefully not a stock one.....
Old Jun 16, 2005 | 01:39 PM
lesser85's Avatar
Car: 85 Z28
Stock ECU out of '85 IROC with hypertech stage i chip. I had the same issues when my engine and computer were both bone stock.
Old Jun 16, 2005 | 01:46 PM
vernw's Avatar
In that case I'd go back to the beginning: Check for vacuum leaks, check compression all around, see if any plugs look different (richer/blackened) than the others, and realize that it will NEVER run worth a tinker's d@mn with that compression, heads, non-stock cam, etc. on a stock chip. And the Hypertech chips are not all that different than the stock ones and in most folks's mind (mine included) are junk and a waste of $$.
Any chance you've done any data logging to see what the engine is really doing?
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
