need distributor wiring diagram
Old Jun 15, 2005 | 01:47 PM
Svelte_SS's Avatar
Car: 1987 Monte Carlo SS
Engine: 5.7L TPI
Transmission: 4 spd auto
for a 1985 hei in-cap model, or any other compatibles...
thanks.
Old Jun 15, 2005 | 09:03 PM
Vader's Avatar
http://www.geocities.com/vtcamaro/Pi...rams/pg152.jpg
Old Jun 16, 2005 | 09:27 AM
Svelte_SS's Avatar
Engine: 5.7L TPI
Thanks!
Old Aug 13, 2006 | 01:02 PM
Svelte_SS's Avatar
Engine: 5.7L TPI
Well after having so many problems with my HEI distributor and I decided to swap to an external coil distributor from a 92 camaro.
I got one off ebay and it's ready to go in.
Anyone have the wiring diagram for an external coil distributor from a 92 that so I know how to wire it into my '85 in-cap harness?
Also, does anyone have a spare external coil mounting bracket or know where to find one? There aren't any on ebay.
Old Aug 13, 2006 | 09:04 PM
RednGold86Z's Avatar
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
</title></head>"); newWindow.document.writeln("<body><div align='center'><img " + getWidth("yes") + "src='/images/cds/" + tpe + "/" + sze + "/" + pc + "." + tpe + "'></img></div>"); newWindow.document.writeln("<div align='center'><table><tr><td><FORM><input type='button' name='sized' value='" + getButtonValue("yes") + "' onClick='javascript:window.close();opener.pop(\"" + pc + "\",\"" + tpe + "_" + sze + "\",\"" + getValueToPass("yes") + "\");'></FORM></td>"); newWindow.document.writeln("<td><form><input type='button' value='Close' onClick='javascript:window.close()'/></form></td></tr></table></div>"); newWindow.document.writeln("<br/>"); newWindow.document.writeln("<div align='center'><font face='Veranda, Arial, Helvetica, sans-serif' size='-2'>Copyright © 2002 Delmar, All Rights Reserved.</font></div></body>"); newWindow.document.writeln("</html>"); newWindow.focus(); newWindow.document.close(); newWindow.print(); } function pop_norm(pc, tpe, sze) { newWindow = open("","","directories=no,menubar=yes,toolbar=no,location=no,scrollbars=yes,resizable=yes,height=400,width=700,left=50,ScreenX=50,top=120,screenY=120"); newWindow.document.writeln("<html><head><title>
Old Aug 15, 2006 | 10:28 AM
Svelte_SS's Avatar
Engine: 5.7L TPI
Thanks!
Are there any distributor removal / installation walkthroughs on this site? I checked the tech articles and did a search but couldn't find any.
Also, does anyone know where to find an external coil mounting bracket?
Old Aug 16, 2006 | 12:40 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
wow, this will be interesting. Your 85 uses an older style 7-pin ignition module. The dizzy you got from a 92 will have the 8-pin computer controlled module. Your computer will have to figure all the ignition timing, since that dizzy has no advance mechanism. Are you putting in a computer from 92 as well? On the 8-pin module, the pins on the inside go to the magnetic pickup. the smaller external connector goes to the coil, the larger external connector goes to the computer.
Old Aug 16, 2006 | 10:55 PM
jetblast's Avatar
Car: 91 z28 convertible
Transmission: 5 speed
thanks for the wiring diagram
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
djmarch
Aug 19, 2015 12:07 PM
