changing heads.. what to secure them with?
Old Jun 20, 2005 | 04:01 PM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
when changing heads.. what is better to use, bolts or studs?
does it make a difference at all?
also does anyone have a GM part# for a 350 head gasket set for a 92??
Old Jun 21, 2005 | 09:23 AM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
Studs are supposed to be stronger, but any good quality bolt from ARP will work awesome for your setup....some people have had leaking problems with studs as well....bolts are easier to work with for me. Just make sure you clean and tap all the threads to ensure an even torque on all the fasteners and you'll be set.
Old Jun 21, 2005 | 06:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You might have trouble getting the heads on with studs unless you plan on pulling the engine.
Old Jun 21, 2005 | 07:11 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
ARP's cylinder head studs now come hex-broached (sp?).. Meaning that they have a little spot for an allen wrench at the top. Should make them pretty easy to install once the head is sitting on the block. Boy I wish they came out with those before I bought them..
Old Jun 21, 2005 | 07:45 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I had heard through the grapevine that you cannot remove the heads with studs in a thirdgen with the motor still in the car. I don't know if it's true or not, but it's something to think about.
Old Jun 21, 2005 | 08:01 PM
thirdgen88's Avatar
Car: 1995 Corvette
This is true.. Not enough clearance by far. But if you get ARP's new head studs, it won't be a problem, as you can install them at the same time you would install the bolts on a head installation. Just don't forget thread sealant (liberal amounts) on the threads!!
Old Jun 22, 2005 | 01:10 AM
firehawkslplus's Avatar
Car: 91 Firebird Dark Green
Engine: 350 Victor Jr. 2V 2000 CFM TB EFI
Transmission: 700R4 BM 2500 stall
Axle/Gears: 3.73 Zexel torque sensing Posi
My experience is that the HVAC box on the pass. side and the Pwr. Br. booster/master cyl. on the dr. side.
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
BAMiller
Sep 14, 2015 06:38 PM
z28guy134
Sep 1, 2015 11:50 PM
Tonyy_z
Aug 12, 2015 07:20 AM
