Torqing the runners???
Old Jun 21, 2005 | 09:33 PM
tpiten's Avatar
Car: 1994 s-10 with a TPI 5SPD
Transmission: Muncie 5 SPD
I got my truck running but i can here a vacuum leak on the bottom side of the drivers runner(plenum end) i used a peice of fuel line to my ear to find it.I removed the plenum and put a non hardening sealent on the gasket and there is no change. All these parts are off the same car so it is not like I have got incorrect runners with the plenum etc. Is there a procedure I am missing?? When I put the engine together I tightened down the runners on the intake then installed the plenum. Is this incorrect? What do you guys do???
Please help!!! Thanks
tpiten
Old Jun 22, 2005 | 02:30 PM
billyhoss's Avatar
i would make sure u got the runners on the right sides, i have heard if u get them mixed up u will have a vac leak, double check that
Old Jun 22, 2005 | 07:12 PM
Vader's Avatar
The few times I have done it, I have had no sealing problems. I've installed the lower and upper runner bolts hand tight (a matter of inch/pounds) then started at the lower runner-to-intake bolts, working from the center outward to about half torque (9 ft/lb). Then tighten the upper runner-to=plenum bolts to about half torque. Return to the lower bolt and torque to 18 ft/lb, again working from the center outward. Finally, return to the upper bolts and do the same. If you are removing the runners, inspect the gaskets closely for evidence of the contact area. Any places that have poor contact should be apparent.
Old Jun 22, 2005 | 09:39 PM
tpiten's Avatar
Thanks guys!! Problem solved, the 9'th injector was not seated properly, it is hard to see when she is all together! Once again thanks!
Linson
Oct 24, 2025 02:00 PM
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Chas91Z28
Oct 22, 2015 10:12 AM
Royal_Z
Sep 30, 2015 08:45 PM
