convert carb to FI recomendations
Old Jun 23, 2005 | 05:49 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I am about to convert from carbureted setup to a tuned port/super ram setup. I would appreciate all you have done this or knows whats involved on this swap,to please add your two cents please. things that come to mind- accel cable-TV cable are different for tpi - is stock tpi cables long enough for the superram? compuer swap-,wiring needed? fuel system? i know ill need a intank pump but will carb lines work ? or special mods to handle higher fuel pressures? - just trying to get all the ducks in a row so it takes me 2-3 or 3-4 days not months because i didnt think this out first currently there is a 383 with stock carb with all comp operational and meets smog sniffer . thank you all on TGO as i have been reading all the threads i see there is a great amount of knowlege right here you guys rock !
or if you know of any other threads can you put a link on here?
thanks
Old Jun 23, 2005 | 07:18 PM
Parrydise7's Avatar
Try the search function. There is a lot of information available.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
andy74
Sep 3, 2015 08:41 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
Dialed_In
Aug 20, 2015 01:45 PM
