Cleaning throttle body
Old Jun 27, 2005 | 12:54 PM
RED92Z28's Avatar
Car: 92 Z28 TPI
Engine: 305HO
I know you should use brake or carb cleaner to clean a throttle body, but can you use a carb dip with a basket to clean it? Mine is really, really cruddy and I don't think it will clean up with a spray cleaner.
Old Jun 27, 2005 | 02:03 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
that would be fine to do.
However I do recommend getting a TB rebuild kit from the dealer and strip the throttlebody when u do.
U dont want any of the sensors in that stuff and do to age(least 13 yrs) a thourough cleaning and overhula wouldnt be a bad idea.
later
Jeremy
Old Jun 27, 2005 | 03:26 PM
RED92Z28's Avatar
Car: 92 Z28 TPI
Engine: 305HO
Thanks for the input. I was going to rebuild it anyway, just didn't know if the dip would do bad things to the metal.
Old Jun 27, 2005 | 04:04 PM
kevinc's Avatar
Car: 1982 Z28
I avoid dipping TBs in the harsh stuff, just stick with Mr. Gasket Throttle Body cleaner aerosol spray. Some TBs have a finish which the dips remove, next thing you know you've got surface corrosion everywhere.
Also, if you do go the dip route you'd best remove the throttle shaft and re-grease the bushing surfaces.
Old Jun 27, 2005 | 04:19 PM
RED92Z28's Avatar
Car: 92 Z28 TPI
Engine: 305HO
Thanks, Kevin. I'll do that.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
