1986 TPI Plenum lower side ports with pic
Old Jun 28, 2005 | 07:51 AM
My1986IROC-Z's Avatar
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Can you guys tell me where to route these connectors to, bottom side of plenum in the rear.
Tony
Old Jun 28, 2005 | 08:54 AM
dperk's Avatar
I"m not 100% on these, but they are all vacuum lines. The large one #1 is usually for large draw items like power brakes or a vacuum distribution thingy.
#2, I'm not sure. May be pollution stuff.
#3 I have connecting to my Fuel Pressure Regulator.
Old Jun 28, 2005 | 11:44 AM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
#2 Is to the MAP sensor
Old Jun 28, 2005 | 12:47 PM
Abubaca's Avatar
1 is the brake booster
3 is the Fuel pressure reg.
2 ...hehe...it goes into a "t" fitting. Big help, I know, sorry.
Old Jun 28, 2005 | 12:51 PM
Abubaca's Avatar
...mine is an 89, I'm guessing it's the same.
I'm sure one of the experts will chime in here soon!
Old Jun 28, 2005 | 01:03 PM
Car: 1986 Iroc-Z
Thanks for the pic. I am making my hand drawn schematic of all the vacuum lines so I understand them and that I have all the parts necessary when I get ready to install everything. Pics always help!
Tony
Old Jun 28, 2005 | 01:30 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
It really doesn't matter where they go, it's all vacuum. Things that require vacuum from the plenum (that I remember, I only have 3 lines remaining on mine) are:
Brake Booster
MAP sensor
EGR solenoid
Heater control valve
Cruise Control
Old Jun 28, 2005 | 03:47 PM
Dr.NickRiviera's Avatar
Car: 1987 Trans Am
Engine: tree-fiddy
1. Brake booster cable.
2.EGR diverter valve
3. fuel pressure reg.
Old Jun 28, 2005 | 06:23 PM
Abubaca's Avatar
I thought it might be the EGR div. but didn't wanna guess.
Thanks.
Old Jun 28, 2005 | 10:32 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I don't think so, the EGR solenoid gets its vacuum from the ported source at the bottom of the throttle body. Since this is a MAF plenum, #1 is the Brake Booster port, #2 goes to a two-way check valve (one output side feeds the HVAC, the other side feeds the cruise control), and #3 is for the fuel pressure regulator. If this was a SD plenum, it would have a #4 which would be for the MAP sensor.
Old Jun 28, 2005 | 10:40 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
88 has ALL the correct info.
Old Jun 28, 2005 | 10:54 PM
Abubaca's Avatar
Glad I didn't jump the gun!!! It's all Dr. Nick's fault!!! haha
I was only agreeing.
Fast355
Dec 2, 2016 06:33 PM
MantyZ28
16
Dec 21, 2015 11:02 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
sailtexas186548
Brakes
Aug 13, 2015 11:47 AM
mx127
Aug 10, 2015 08:13 AM
