Converting to SD from MAF
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
I did a search and I'm still a bit concerned about the swap. I can wire it and will probably feel better if everything is in front of me, but I'm heading to the junkyard and I'm worried I'm going to forget certain necessary parts. Could someone tell me if I need anything besides:
730' ECM with a few inches of its wiring harness.
Knock Sensor
MAP sensor
Knock Sensor
MAP sensor
Car: 89 IrocZ
Engine: L98-ish
You need a memcal for a SD car with a 5.0 and whatever transmission you have. You also need a 1/4" vacuum T fitting/hose, not to mention something for your CAI to replace the MAF sensor, and some wire to short the EST knock leads.
Car: 86 T/A
Engine: HSR 355
Car: 86 T/A
Engine: HSR 355
Oh ok, I think I get it. The 730 is a universal ECM, but the memcal is specific for the engne and tranny combo.
Car: 86 T/A
Engine: HSR 355
Another question- will I need to reprogram the memcal if it came from a 5.0L auto like my car is right now? I saw it'll need VSS and VATS changed, does everyone that do this swap have burning software?
Car: 86 T/A
Engine: HSR 355
I'm just really confused because in the list of parts needed from that website it included a prom burner but I wasn't sure if that was to make it run or to custom tune your car. I just want to convert my car since the MAF died and I don't like having it in my air flow.
Car: 86 T/A
Engine: HSR 355
That's what I figured but I want to make sure before I invest some money and time in a bunch of parts.
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
