My dyno sheet
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
My dyno sheet
I have one that made 305 hp and 405 tq but I cant get a good pic of it so heres the next best one.
I dont think its too bad for being built very mild to pass emissions
here's some specs
406 block
superram w/tpis base
crane 2050 compucam
trickflow heads
about 9.5 to 1 compression
built 700R4
2500 stall
edelbrock headers
hooker cat back
3:73 rear
here's some specs
406 block
crane 2050 compucam
trickflow heads
built 700R4
2500 stall
edelbrock headers
hooker cat back
3:73 rear
Car: Formula, a big red brick.
Engine: A Ford 351 Windsor... ?
Transmission: Dodge 727
That looks good for a deep 12 second run to me.
Let me know if you take it out to Norwalk. There should be a group of Third Gen'ers going for a Pontiac weekend coming up soon.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Very good. Horsepower is similiar to mine. I'm posting my graph so I can compare the HP curve. You should be well into the 12's. Good luck.
Edit. You have more power down low than I which is to be expected. Should do real good on the street and pin you back into the seat.
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Dam I wish I had gotton a graph like that!! I had some sort of print out. I bet if I had it cooled more and timing fixed I bet I would find the additional 9TQ to be over 400 and also I am hoping to find a few more RWHp as well
Wow 1989, I wish I could see a sample from 2.5k through 5k, that torque line looks amazingly flat from 4,250 to 4,750.... really make me interested to see what's before it.
How many miles do you have on your shortblock?
Car: 1985 Trans Am
Cam Card here. I wish I put in a bigger cam now, but I am done with the motor unless something stupid happens.
Car: 1989 GTA
Engine: 369 TPI
Hi Goy
I suspect the torque curve is relatively flat with a little higher number down lower but not much. In my opinion it is still to much as I still have problems hooking up at the track even with the Mickey Thompson ET Street Radials.
On the street tires I will roast them in 1st gear and it spins pretty good in 2nd gear as well. Allen
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
nice mild motor! bet it runs very well on the street.
that makes impressive power for such a small cam... i would like to see what a decent sized cam could do in a motor like that
It looks like you have a mismatch somewhere in your combo. A well matched 406ci should be making at least 350 rwhp and be very streetable/smogable. It looks like there is 50+ rwhp hiding somewhere there.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Strong runner indeed, Might meet at a light sometime (just not in Parma
) Had enough fun with those guys.
Are you burning your own chips and logging?
) Had enough fun with those guys. Are you burning your own chips and logging?
Car: 1985 Trans Am
I know what you mean with the Parma PD. www.lsracingchips.com did my tuning and datalogging.
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
gta892000
Sep 16, 2015 12:37 AM
