89 TPI swap into a 77 vette-issues
Old Jul 19, 2005 | 07:30 PM
civic4ges's Avatar
We finally got this swap up and running, and run into a few issues.
Here is a littel background info
1977 Vette
5.7L 350
Manual tranny
89 TPI intake componenets/distributor
S10wildslide engine harness
Moates adapter in ecu
When running the car with the APYU bin, after removing the vats and setting it for a manual tranny, the car is non-responsive and I get a cel code 33...MAF sensor voltage too high
I have ran a BIN called 89vets...which did not give me the MAF cel code 33 reading, but still is not responsive
Anyone have suggestions on what map I should use to get this car running somewhat correctly with just a basemap???
The only roms I have been able to ID as being compatible thus far are APYU, APYP, and AUTM. Anyone know of more, or the precise once I should be running??
Old Jul 24, 2005 | 11:10 AM
Vader's Avatar
Is the CALPAK from a 350? Backup Mode may not be ideal for the setup if the donor CALPAK does not have the 350 TPI data. Is the system reaching closed loop?
There are many bin files that will run your setup. ARAP seems to be a pretty good base.
Old Jul 24, 2005 | 09:20 PM
civic4ges's Avatar
I got some help from s10wildside, and a spare MAF sensor. All is well, get an intermitent EST code, and a VSS since we have none hooked up
All seems to be well
Old Jul 25, 2005 | 11:57 AM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Have you ensured all the basics are correct? Timing, fuel pressure, etc?
Old Jul 25, 2005 | 08:24 PM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
i had pretty good luck when i installed it in my 73 vette,but i have a 700r4 also,im using an arap file on mine.
Old Jul 26, 2005 | 10:37 AM
civic4ges's Avatar
I have tried an arap bin with little luck. All seems to be working well now, except for a VSS sensor issue (using a mechnical VSS, so no drive for the ecu at this point).
On this note, does anyone happen to know if a sensor is made to allow both cable drive, and electrical output from the vss sensor, possible an entire replacement sensor??
Old Jul 26, 2005 | 11:54 AM
nitrovette's Avatar
Car: 73 corvette
Engine: 2004 ls1
im using a painless wiring one that is mechanical going to my autometer speedo and electronic for vss signal.It screws on to a stock speedo drive then your speedo cable screws onto that then theres 2 wires coming out of the side of it for the vss signal.Summit sells them
Old Jul 26, 2005 | 04:16 PM
civic4ges's Avatar
Nice to know...will check it out shortly...Thanks for the help
Chris
Old Jul 26, 2005 | 08:53 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Also try "jagsthatrun.com"
They have a bunch of different options and some good info just to see what is out there.
Old Jul 27, 2005 | 01:18 AM
Ollie8974's Avatar
Car: 1979 Zcode TA
Engine: 220hp 400ci Building a EFI 455
Transmission: 4 speed
Speed Sensor
Dakota Digital also offers a speed sensor
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
jharrison5
Aug 19, 2015 05:53 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
