Help Meeeeeee
Old Jul 29, 2005 | 12:18 AM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
Help Meeeeeee
I've got a couple of wires that I cant figure out where they go..
This one plugs into that black box "outlet" in the picture, and then another wire off that same black box leads to my coil...
http://memimage.cardomain.net/membe...61_108_full.jpg
This one was behind my coil on the wiring harness..
http://memimage.cardomain.net/membe...61_109_full.jpg
if those links dont work...
http://www.cardomain.com/ride/751861/5
last 2 pictures in order..
please help, this stuff is driving me nuts
Old Jul 29, 2005 | 12:26 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
The first one looks like the connector for the egr temp swith, should be a sensor with a pigtail coming off the egr valve.
Second one looks like MAT sensor. Under the plenum, near the back, on the drivers side. (good luck....)
Old Jul 29, 2005 | 12:37 AM
Car: 1991 Z28
Engine: SBC
ok thanks i appreciate the help, ill check it out tomorrow morning and tell you if it was right or not...
...i sure hope it is...
Old Jul 29, 2005 | 09:17 AM
Car: 1991 Z28
Engine: SBC
got the 2nd 1, it plugged in underneath my coil. I just cant get the 1st one, its not the egr, i tried that. Some people on Z28.com are telling me to take the black 1 off the black "box" and put in on my coil, and then that same end should go into my distributor. But i already have a wire leading to my distributor?
In my old engine pictures i had 1 wire leading to my coil...
i have a digital ignition too, if that means anything at all
Old Jul 29, 2005 | 03:46 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
Are you sure it isn't for the egr vacuum valve under the coil? Sure looks just like mine.
Old Jul 29, 2005 | 07:01 PM
Car: 1991 Z28
Engine: SBC
Yea that one went under my coil...to that little black bracket with the two vaccum lines off it..yea it plugged in there, but the other 1 i cant get...
Old Jul 29, 2005 | 08:55 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
1st one get to the back of the dirtributor on the ignition module and the other is part of the EGR silonoid.
Old Jul 29, 2005 | 10:39 PM
Car: 1991 Z28
Engine: SBC
got em all..thanks guys...wound up my accel ignition caused some things to be alittle different
cedric85745
Feb 27, 2005 01:31 AM
