tpi harness, use a v6?
Old Aug 4, 2005 | 08:41 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
can you use a v6 harness that goes to the 7730 computer and just add 2 more fuel injector plugs? i looked through the book really quickly and it looks as if it's wired the same, anyone done this?
Old Aug 4, 2005 | 01:14 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Almost all GM harnesses from anything that had an ecm in it are very simliar in nature. Most sensor wire colors are the same from engine to engine car to car even.
I dont have a manual in front of me now, but I have seen CCC, TBI and TPI(maf) all made to work with SD TPI. Works well if u have the time and inclination as well as a decent harnesss to start with.
So I do not see how using the 6 cylinder harness might be any different.
Would do some wire checking as far as length is concerned, if u have to add to every wire, it would be easier to start out with a conversion from a v8 harness
later
JEremy
Old Aug 4, 2005 | 09:29 PM
Z69's Avatar
Z69
I'm converting a 4cyl harness and only a couple of wires needed to be moved and fix the injector wires.
stalkier
Dec 6, 2015 11:25 PM
fbirdroller
Sep 2, 2015 10:27 PM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
